V6 to V6 swap
Old Aug 10, 2003 | 06:31 PM
mm68's Avatar
V6 to V6 swap
I have a 92 firebird 31. 700 at trans . The engine threw a rod. Besides the 3.1 , what other V6 engines will bolt right in with all acces. including ac . I read the 3.4 boogie Will that drop right in my year . I think my chooses are 2.8 / 3.1 / 3.4 correct me if i'm wrong . I would use all my senors as they were all good and not change anything with the computer . what othr cars came with these engines?
Old Aug 10, 2003 | 08:31 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
yes, yes, yes, and 1993-95 F-bodies. Some 95 models came w/the 3.8 engines, but they were only the cali cars.
Old Aug 11, 2003 | 11:35 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
For pics of such a swap, see http://www.geocities.com/tomp_3rdgen
Old Aug 11, 2003 | 12:31 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
im sure it was covered in keds article, but make sure to get the 3.4L out of an f-body. Like the 2.8L/3.1L the engine does an excellent job in front wheeled drive cars also, and is equipped in monte carlos, luminas, impalas, etc.....so, stick to rear drive, it'll be much easier on ur swap.
Old Aug 11, 2003 | 02:01 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Oh yeah, try to avoid the 81-84 2.8's. They have smaller crank journals, a less-powerful camshaft, and less-flowing heads. If you've gotta go with a 2.8, try to get 85-up.
Hm, actually, on f-bodies (Camaro/Firebird), I know that for sure regarding the camshaft and heads. I don't know how the cam and heads were the same/different for S10-Blazers.
(The crankshaft issue went for all 2.8's.)
Old Aug 12, 2003 | 12:16 PM
mm68's Avatar
thanks
thanks all for the info . This is a great forum with tons of info Imostly use the seach but i just wanted to make sure I get everything strait. thanks again
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
