disappointing track times.....
Old Aug 16, 2003 | 07:44 AM
camaro_V6_Tuner's Avatar
Car: 2002 Trans Am WS6
Axle/Gears: 4.10
i have a 87 camarov6 3.4 auto and took it to the track last night. i was really disappointed that i just barely broke 18 seconds. is that about right or am i doing somehting wrong?
Old Aug 16, 2003 | 08:10 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
alot of things can change track times, including non-car related things.
outside air temp
altitude (sp?) to sea level
auto vs manual
all things removed from car (radio, spare, floormats, etc.)
Bad reaction times to the lights/tree
bad tires (or even larger tires slow you down)
car not being alighned
something wrong with engine.
all this, and more change them times.
Old Aug 16, 2003 | 02:01 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
camaro tuner,
The best suggestion i could give ya would be to take ur timeslip (for ur best time) or multiple times if you've got them all, and then post the entire slip, you can normally tell if you're spinnin the tires to much, or if you're RPM's are way out of the powerband by looking at the entire slip, and some people on here might have some advice to help you.
Bubbajones_ya
Oct 25, 2015 08:01 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
jaridjohn
Oct 5, 2015 07:01 AM
Numbah-1
Oct 2, 2015 08:27 AM
