What is thing???
Old Aug 17, 2003 | 06:49 PM
BitchinRS's Avatar
What is thing???
Ok I replaced my starter yesterday. half of the solinod plastic cover was broken. Explains why it was a fifty / fifty chance that it would or wouldn't start. Found that the lower exhuast manifold bolt for the #5 cylinder is busted. Explains why that one runs realy lean all of the time.
While replacing the starter I noticed a funny hard line coming off the trans and up by the distrutor, but low enough that you can barley see it from the top. It runs from the top of the trans near the rear to this spot. On the end it has a wierd cap. it flaps around kinda like the top of a presure cooker. Does any one know what this is? Is it some sort of presure relief valve? I can't find a reference to it any of my books.
Old Aug 17, 2003 | 07:36 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
nothing exactly liek that in the service manua, except a vent on that side.
Old Aug 18, 2003 | 10:34 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
....that's the strangest thing I've ever heard of! I have NO idea man.... So the cap on it opens and closes??
Old Aug 19, 2003 | 10:24 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yep; pressure vent. Although my '86 has no end to the tube; it's a yellowish (probably clear at one time) tube that hangs off the top of the bellhousing and points down. Yet another reason to be wary of a car that's been in a flood.
There's also a vent tube on the rear axle... so if you ever take your car swimming, change the rear fluid.
Old Aug 21, 2003 | 11:50 PM
BitchinRS's Avatar
Cool. Just had me wondering what the hell is this thing. I didn't know that manual trans needed a presure relief valve.
Old Aug 30, 2003 | 11:49 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
There is no pressure inside a manual trans. It's just a vent.
morrow
Jan 13, 2024 12:29 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
TheExaminer
Aug 19, 2015 10:07 PM
Bob88GTA
Aug 18, 2015 03:31 PM
