posi?
Old Aug 29, 2003 | 02:21 PM
syknesss's Avatar
Car: 91 Firebird
posi?
how can i tell if my 91 rs v6 has posi or not? it has the 4 speed auto with overdrive if that helps
Old Aug 29, 2003 | 03:35 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
chock front wheels, put in drive. raise rear by axle pumpkin. rotate one wheel forward. sneak peek at other wheel. if they both are gong forward it's posi. if they go opposite, yo have teh one tire fire.
Now that I think about it, this was one of the ways we checked on my 77 T/A. The twin plow marks ini the feild were the other <---- It was a 4sp
Old Aug 30, 2003 | 11:38 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
That method (raise both tires and spin one by hand) won't work for a posi that's a bit worn out. Only true way is to remove the rear cover and have a look inside.
Old Aug 30, 2003 | 06:24 PM
Anjiru's Avatar
Shouldnt the car be in Nuetral and off?? then you spin the tire???
The best way to me is to see if it's posi is to look up the number on the front of the right axle housing and the first three digits is the identification code of the axle(the rest of the numbers tell you when it was made etc..) and another plus of looking it up is you can tell the axle ratio oh and one more thing I identify them with the book so if you dont like have the book or know where you can identify this is pointless.
Old Aug 30, 2003 | 06:32 PM
Engine: 5.7 / 7.4
provided the axle number is still legable. Axle number IDs are inteh holly book haynes btw
Old Aug 30, 2003 | 07:46 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
I don't think that any of the V6's came with posi stock. Unless someone has had the ambition to put posi in it aftermarket, then it doesn't.
Old Aug 30, 2003 | 09:56 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Check your RPO codes for G80(Limited Slip).
Old Aug 31, 2003 | 11:46 AM
88camarov6's Avatar
Car: 87 Camaro Vert
Engine: Cammed LT1
Just do a Power Brake. Tells ya instantly.
Old Aug 31, 2003 | 01:26 PM
syknesss's Avatar
Car: 91 Firebird
raised it put it in drive and spun i got the one tire fire
KO1
16
Oct 15, 2015 05:00 PM
92projectcamaro
Sep 29, 2015 07:07 PM
