Burning real rich
Old Aug 20, 2003 | 11:25 AM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
Burning real rich
I recently swapped in a new cam, so I had to adjust the rockers of course. I also had my injectors cleaned. I would assume the computer would have adjusted to all this stuff since the cam is the emissions friendly ( and weak) powermax 2030.
I am thinking maybe one of the rockers has loosened itself since the engine just started burning this rich recently
OR
I replaced my O2 sensor in the spring, but didn't know not to touch the tip of it so I may have. I am thinking that if I did touch it, the oils on my finger would make the tip feel hotter so the sensor would think I was lean and give me more gas. Am I right?
Old Aug 20, 2003 | 09:26 PM
somebody, anybody?
Old Aug 21, 2003 | 12:12 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
you poking fun a me?
What codes you getting so we cain better assist you in your time of need
Old Aug 21, 2003 | 12:36 PM
yeah
no codes
Old Aug 22, 2003 | 08:58 PM
so just to recap....no codes, and I'm running real rich
Seems like there's nobody on the boards lately ......maybe everyone is on their way to Harley's 100th anniversary party here in Milwaukee
Old Aug 23, 2003 | 12:54 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
How do you know you're running rich? Did you do a diagnostic with a computer, or did you read the plugs? How's your major tuneup status?
Old Aug 23, 2003 | 10:26 AM
I know its running rich just because of the exhaust...it just smells like gas. I will check the plugs today. As far as a tune-up goes, Everything in the ignition has been replaced aside from the distributor cap and rotor,
I have done in the last about 700 miles
new fuel filter
oil change
tranny fluid + filter change
timing is at the stock spec....gonna recheck that tho
Injectors have been cleaned
I have k&n air filter
The only things on your list I haven't done are rear axle gear lube, distributor cap and rotor, and pcv valve
It seems to run the richest right after start up, for the first few seconds, and the revs jump around between like 500 and 1500 during that time
Pac J
May 17, 2020 10:44 AM
mattcanty
Oct 12, 2015 11:08 AM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
