F***in previous owner
Old Aug 20, 2003 | 08:28 PM
Skatepunk60's Avatar
Car: Hardtop 84' z/95' Cheyenne
Engine: 305 H.O./4.3L
Transmission: 5-speed manual/Auto
Well i got the oxy sensor today .. and it looked kinda easy so i got under there and bam .. the f*cker hit it with a mig. Not the whole thing but like three dots. What can i do to fix this problem? i dunno how strong they are but i need a cheap solution.
Old Aug 20, 2003 | 08:33 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
drill, metal chisel & hammer, screw driver & hammer (when proper tool cost too much/unavailable)
Old Aug 21, 2003 | 09:07 AM
Ovrclck350's Avatar
Or take the easy way, go to an exhaust shop, have a new 02 fitting welded in for ~40 total.
Old Aug 21, 2003 | 11:47 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Depends on what tools you have to your access.
No tools, take to muff shop. (350's idea)
Basic hand tools, attempt chissel and hammer (projects idea)
Lots of power/air tools, die grinder, cut the welds, remove it, grind area clean, install some wd40 in the hole, and screw new one in.
Old Aug 21, 2003 | 12:30 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Buy an electric grinder from wal mart... grind welds away, return electric grinder.
No cost overall
Old Aug 21, 2003 | 01:30 PM
JoshDT91's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 2.8L V6
I got one that tops that. The previous owner of my car SUPER GLUED the bulbs in the high mount brake light. So when one burned out I had to go searchin for the part of the light that holds the bulbs. The moron claimed the bulbs were like $15 a bulbs or somethin, here I go to Wal-Mart or Advance and see them for $7. What a moron, we should give awards to the O2 man for being a moron too. Why would you MIG a O2 sensor in? I would think the direct heat on the O2 sensor would damage it more so than hot exhaust.
Old Aug 21, 2003 | 01:34 PM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
The guy I had work on my car a few years ago welded on my bolt-on cat with a whole load of weld so that I could never replace it again. I had to take the whole y-pipe off.
Old Aug 21, 2003 | 01:54 PM
SYM Rule's Avatar
Previous owners suck so bad.
Check out my cardomain site sometime for an interesting story.
Old Aug 21, 2003 | 04:08 PM
i got a but load of tools at my disposal .. i ll try to cut it w/ the die grinder
Old Aug 22, 2003 | 09:37 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
First: Amen to the previous owner comments
And on the spoiler-mount CHMSLs, at 35 bucks for 5 bulbs that will burn out again, I say screw that. With a little inginuity and some solder to strengthen the posts, good 'ol 194 bulbs can be modified to fit in the CHMSL.. at about 5 bucks for the assembly
Old Aug 22, 2003 | 10:08 PM
Engine: 5.7 / 7.4
:sillylol: :sillylol: :sillylol: at third brake light
Old Aug 23, 2003 | 12:39 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The guy might've had the oxy sensor welded on because he stripped out the bung... you might wind up having to do what Overclk350 says...
Lbibb
May 5, 2016 12:00 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
z28joe2
Sep 28, 2015 05:54 PM
indygene
Sep 26, 2015 11:21 AM
