rocker arms
Old Sep 9, 2003 | 10:31 AM
paintshooter's Avatar
rocker arms
I just got the new jegs catalog today and saw some rocker arms for the 2.8. They are made by comp cams and they claim to give you 15- 30 hp. I was woundering if anyone has done aftermarket rocker arms and what difference did you feel?
Old Sep 9, 2003 | 03:12 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Are they full roller rockers or roller tips? Whats the ratio? 15-30 hp is highly unbelievable. I'd say 5-10, 10 being absolute tops...
Old Sep 9, 2003 | 10:41 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
small block rockers fit our motors too. just watch the stud size, i think we got a metric size (10mm i think) where small blocks are normally 7/16" i believe. i am running 1.6 roller tips for a small block on my 3.1 i just reused the stock pivot *****. small block rockers are probably cheaper and definately more common.
Old Sep 9, 2003 | 10:55 PM
the ratio is 1.52 on the rocker arm
Old Sep 9, 2003 | 10:59 PM
the part number on jegs website for the magnum rocker arms is 249-1413-12.
Old Sep 10, 2003 | 12:29 PM
Nixon1's Avatar
15-30 hp out of rockers only 1.52 ratio on a V6? Hehehe....suuure.
Those aren't even FULL roller rockers, they're only roller tipped....
You'd be better off with some 1.6's....add some more effective lift to the cam. And get full roller rockers if ya can for a decent price....
Old Sep 12, 2003 | 11:53 AM
Brian K's Avatar
Do not go bigger than 1.52 unless you replace valve springs.. My buddy did it on his tired 2.8 and it became a real dog... He lost power low end big time... 1.6 roller rocker I think 105# valve springs are the key..
Old Sep 12, 2003 | 05:26 PM
rleprechaun's Avatar
Car: 1987 TransAm
Engine: 350 Goodwrench
Transmission: 700R-4
Comp 1413 rockers are 1.52 ratio. Comp 1414 rockers are 1.6 ratio. They are the only aftermarket rockers specific for the 2.8, 3.1, 3.4 10mm rocker arm stud. Use GM valve spring 12363215. Valve springs can be changed without removing the heads when going to Comp Magnum roller tip rockers.
Old Sep 12, 2003 | 09:04 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I coulda swore that small blocks used a 3/8" stud... not 7/16"... no?
Old Sep 12, 2003 | 11:28 PM
Car: 1987 TransAm
Small blocks and 4.3 V6's use a 3/8 rocker arm stud. 60 degree V6's 2.8, 3.1,& 3.4 use a 10mm rocker arm stud.
Old Sep 13, 2003 | 01:18 AM
Car: 91 Camaro
my fault, sbc's are 3/8 not 7/16......i got mixed up.
Ed1LE
Sep 30, 2018 09:14 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
1HotZ28&SS
Sep 28, 2015 08:58 PM
