Power steering hose?
Old Sep 9, 2003 | 07:42 PM
Jurrel's Avatar
Car: 1984 Firebird
Engine: 2.8 Carburated
Transmission: T5 Manual
Okay my high pressure power steering hose *Aren't they both high pressure?* is leaking madly...I can get a new one from Kragens for 20$, so how hard is it to repalce this? I have had a few shops quoting 100-150$ for replacement of the hose. Is it that big a pain, or they just making big bucks of this?
Thanks!
Old Sep 9, 2003 | 08:26 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
loosen old hose, catch drain off, replace w/new hose, use some teflon for cheap stop leak insurance, tighten to spec, fill resovoir, start & check for leaks.
The drain back hose isn't as high pressure as the primary one. You cain get that hose in bulk from behind the counter.
Old Sep 9, 2003 | 10:50 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yeah, they just smelled money and figured they'd rape you a good one.
If the tube nuts start to strip, use a large adjustable wrench with thick jaws on the nuts. And wear gloves- when those tube nuts start to turn, you can wind up kissing the radiator with your hand. (Got a "new" scar from that one )
Old Sep 10, 2003 | 11:46 PM
Jurrel's Avatar
Car: 1984 Firebird
Okay well this IS California so I am not suprised they would try to rape me for that....Know of a good place BTW to send a Verijet carb to get rebuilt? they want around $400 for that around here....beh I say...
Thanks 85 2.8 bird, I was hopping it would be easy like that
Old Sep 11, 2003 | 01:19 AM
Engine: 5.7 / 7.4
You're welcome. I haven't had to change out mine yet, but that's what I did when I did the engine swap.
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
evilstuie
Apr 14, 2016 08:52 PM
deracer
Apr 11, 2016 12:04 AM
sailtexas186548
Aug 24, 2015 10:11 PM
