Attn Dale & KED85:
Old Sep 9, 2003 | 11:12 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Attn Dale & KED85:
Dale: When you swapped in the 3.4 w/the SFI, what gauges did you use? It just came to me while I was out driving the bird ( ) . The VSS, electronic tranny, and all that.
Karl: IF everything goes as planned, and you aren't in too much of a hurry for the tach, I'm gonna keep the new gauge cluster & just send you my 85 gauge cluster to use.
Now to findout how many splines our driveshaft yoke has, & how many the 4th gens have.
Old Sep 10, 2003 | 05:59 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I kept the s10 guages. Temp works, aftermarket tach works, speedo doesnt because its a 2000ppm, where camaros are 4000ppm.
4th gen and 3rd gen rear axles are "the same" and interchangeable from what I understand.
Old Sep 10, 2003 | 06:37 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
4th gen rears/axles are approx 2" longer (wider from the front of the car, looking back) than 3rd gens. Only difference that i know of - you can bolt one into the other.
The axles themselves won't swap.
Old Sep 10, 2003 | 11:36 AM
Engine: 5.7 / 7.4
actually refering to teh the part of drive shaft that goes into the tranny. WOndering if the output shafts have the same number of splines.
Old Sep 10, 2003 | 12:05 PM
Dale's Avatar
Engine: 350 S-TPI
yes, search on here, and ppl have put 4th gen driveshafts in their 3rd gen.
Also, if you talk to whats that one guy, he has a 4th gen rear AXLE in his 3rd, along with 4thgen interiour, and engine, and composite lights, and flames, etc etc.
Old Sep 10, 2003 | 11:21 PM
KED85's Avatar
FLAMES?
Yeah the tach deal is fine with what you are offering! THANK YOU!!
GM is real cheap.
There shouldn't be ANY difference in the spine output from our auto trannys.
I believe the 700R4 splines are like on a TH350
As long as you used original sensors all your old gauges should connect & operate without a problem
Old Sep 11, 2003 | 01:17 AM
Engine: 5.7 / 7.4
Don'y be saying flames around here :nono:
Yeah, if everything goes even remotely acording to plan, that new gauge cluster will do and go by wire schematics to ook everyting up (unless I have to use 4th gen gauges & wire it up for that)
Karl, need a rear fold down seat cover? Stained some on the back but no rips. Also have the dash "plaque" thing w/the Firechicken on it that sits i front of the front passeger. I have that "glove box flap thing" now and don't know of anyone else w/teh brown/camel/tan interior.
R3500
Aug 24, 2015 09:05 AM
chevyguy1969
May 8, 2001 08:41 PM
TMoNeE
Apr 28, 2001 08:31 AM
Kory-88Iroc 350 tpi
Aftermarket Product Review
Mar 30, 2001 07:01 PM
SATURN5
Feb 18, 2001 07:54 PM
