magnum roller rockers
Old Sep 15, 2003 | 04:38 PM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
Can I use the Comp cams magnum roller rockers on a 3.1l engine?
It only says for the 2.8.
Old Sep 15, 2003 | 10:36 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
yes, even on a 3.4
Old Sep 15, 2003 | 11:04 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
Many sources will not list the 3.1 motor because of possible confusion between the transverse aluminum head 3.1 and the RWD 3.1 applications. They will work on RWD 60*V6 motors with cast iron heads (2.8, 3.1, and 3.4)
Old Sep 16, 2003 | 12:06 AM
The_Raven's Avatar
Car: 1985 GMC Jimmy/1998 Chevy Malibu
Engine: 3.2L turbo Hybrid/bone stock 3100
Transmission: T-5 soon to be 700R4/4T40E
The Comp Cams Magnum roller tipped rockers will also work on Aluminium head 660s as well (gen2 and early gen3).
Old Sep 16, 2003 | 01:39 PM
Lee7's Avatar
Car: 88 BMW 535i
Engine: 3.5L M30
Transmission: 4HP22E
summit racing has roller tipped small block chevy rockers that work on the Iron head engines, IIRC they are cheaper too.
Old Sep 17, 2003 | 08:40 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
do we have to replace the studs to use these rockers? it says its for 10mm studs, arent ours 3/8? and if you look on the website, it says for chevy, you have to buy the studs for the later models.
Old Sep 17, 2003 | 10:45 AM
Lee7's Avatar
Car: 88 BMW 535i
Engine: 3.5L M30
ours are 10mm, SBC are 3/8
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
