Ticking....
Old Sep 20, 2003 | 12:12 PM
91RSRacer's Avatar
Ticking....
Hey guys. Last night and yesterday afternoon (9/19) when the car gets warmed up after about 20 minutes, when I brake I get this weird ticking noise for 5 minutes. Can anyone tell me what that is? Is it something in the head? Or is it the brake pump?
Its a 3.1 V6 with Multi Port Fuel Injection. Thanks alot.
Phil
--1991 RS V6 MPFI
--1986 IROC-Z 305 TPI
Old Sep 20, 2003 | 12:27 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
It's only when you brake? And it continues after you let off??
Old Sep 20, 2003 | 02:27 PM
91RSRacer's Avatar
It happens after the car is warmed up. When I brake on a hill or on a slight incline it starts and goes on continually for about 5 minutes and stops. Someone said it was a brake pump but now that i've thought about i've never head of a brake pump. So could it possibly be my master cylinder is going bad?
Old Sep 21, 2003 | 01:52 AM
87CamaroMan's Avatar
Car: Chevy Cobalt & Camaro
Engine: 2.2 DOHC/3.1
Transmission: Not so slushy slush box/Slush Box
Axle/Gears: Stock 3.23
You could have a brake sticking. Where at in the car is the sound comming from.
Old Sep 21, 2003 | 10:17 AM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
Sounds to me like what an ABS system does when it malfunctions. ABS systems will tick while they are pulsating under hard braking conditions. If the setup is altered or something is malfunctioning, then the ticking can continue longer than programed.
Problem here is- You don't have ABS- unless someone added it.
Old Sep 21, 2003 | 11:25 AM
91RSRacer's Avatar
It's coming from the engine bay back near the distributor. Someone said if could possibly be an exhaust leak but i'm not sure.
Dingley
May 9, 2003 06:18 AM
