Rotor upgrade, broke a stud.
Was tighting my nuts before a 100 mile trip and one stud broke.
Not having much faith in the others, so I assume they'll break also eventually.
So where online could I order better rotors than stock ?
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
I run ARP 2 1/2" wheelstuds, 12mm x 1.5. http://store.summitracing.com/partde...P%2D100%2D7708
Front rotors are Powerslot.
Lugnuts are Kyokugen lightweight 7 sided lugs- 1.5mm pitch.
front pads are Stillen carbon matrix.
Earls braided lines and solo-bleeds.
Note: rear rotors are Stillen drilled, Rear pads are EBC reds. And a 1LE prop valve. Car stops on a dime, better than a stock 1LE setup.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
how tight were you making them? were you using a TQ wrench or bouncing your weight on a 3' cheaterbar to tighten them? lol
to remove the old ones, tap them out the back with a hammer ( a press is better if you have access to one).. put the new one there and give it a LIGHT tap... then tighten it in with the lugnut.
355tpipickup
Sep 13, 2015 11:35 PM
blackandblue02
Sep 10, 2015 08:19 PM
