Code 34....What to do?
Old Oct 19, 2003 | 05:56 AM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Its a 91 camaro 5-spd
I believe this is low voltage at the MAP sensor. I've checked all vacuum lines and they look good. What should I do before I decide to replace the MAP? Anything else to check or is this a sign that the MAP is going dead? I do have a strange idle problem, idles a bit a rough, idle will jump to 2600 when the clutch gets put in driving in traffic, and will stall at a stop with the AC on.
Old Oct 19, 2003 | 09:03 AM
1991rsblue's Avatar
i had the same thing and replaced my MAP and didn't have any more codes. just remember to erase the code for the next time
Old Oct 19, 2003 | 07:19 PM
pasky's Avatar
Ok, just want to make sure thier is nothing else I can check before I shell out more money for a sensor.
Old Oct 20, 2003 | 11:59 AM
MaxxMitchell's Avatar
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
You can hook up a scanner. Our school has one that will pull the codes and also will tell you how to test a sensor and then help you hook the scanner up to the sensor and graph its signals, and from there we can tell if its bad. Dont you hate that you cant return those pesky electrical components after install?
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
