Got code 32 and 34, need help or advice
Old Nov 10, 2003 | 05:40 PM
WaOnFiRe's Avatar
Car: 1988 Pontiac Firebird Formula 350
Engine: 5.7L
Transmission: Automatic 4 speeds
Axle/Gears: 2.77
Okay, I've got a code 32 and 34 on my 89 Firebird, 2.8L and automatic trans. What is the stuff to check when these codes appears on our cars? I know one of the code is an EGR thing code but we changed it like 8 months ago... Thanks
Old Nov 11, 2003 | 07:42 AM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
check the vaccum lines to the EGR system, i pulled the EGR code up a while back, thought about replacing the whole unit, then found a line that wasn't connected, took forever to find out where it went however (the lil tit was hidden) but eventually it showed up as well and no more EGR issues after it. Make sure there are no free fixes well before you start spending $$ to fix something that isn't broke (yet). gotta love aging cars.
Old Nov 11, 2003 | 01:51 PM
jeremy178's Avatar
Car: '89 Camaro RS
yeah, I had the same problem, only after I hooked that line back up, I found out it also had a hole burnt into it. It's the line that runs off the EGR solenoid right under the one that goes to the valve. It runs under the throttle body. The code 34 is low voltage from mass airflow sensor, check the piece of orange frequency tape inside the sensor, if it's not perfectly flat, its bad.
Old Nov 11, 2003 | 10:38 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Check the relay right next to the MAF too... mine went out on me an cuased that code 34.
Old Nov 11, 2003 | 11:57 PM
85f-bird's Avatar
Engine: 2.8L, LS1
those MAF units can get a lil' pricy also....i was having tons of trouble with my car for a while, buddy gave me a remanned MAF he had lining around for his ole' 2.8L maro, swapped them, problems were still there, couldn't figure it out took the car to the shop, (bad wires on the coil, bad wires to the distributor (not plug wires), bad MAF, bad pickup coil....list went on forever, they fixed everything and placed another remanned MAF unit on the car ... said they were trying to save me a lil cash (think it was like 150-200 instead of the 500 the factory watned for a enw unit.
Old Nov 12, 2003 | 01:30 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
what year MAF???
Think I paid like $30 buck for mine at autozone.
92firebirdguy
Sep 1, 2016 07:53 AM
BumpaD82
Feb 26, 2016 02:57 PM
lethaldomestics
Sep 21, 2015 01:18 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
mrdevontay
Sep 2, 2015 08:04 PM
