next thing to fix
Old Nov 16, 2003 | 09:31 PM
90flames's Avatar
next thing to fix
hey board,
I'm back for some feed back, i'm getting tired of putting money in my bird with no result. I just got through a overheating problem and now i'm working with a timing/starting problem. My car will not keep a steady time, it jumps at least 4 or 5 degrees every couple rotations. I have changed the plugs, the module, the coil, and put an new distirbuter cap on, as well as putting a new timing chain on it, and it still does not help. the next thing that has been suggested to me is to change the distibuter altogether. is this a good next step, or am i heading in the wrong direction?
anything helps
Old Nov 16, 2003 | 10:32 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Are you sure the distributor clamp is holding it down properly? Have someone else watch your timing and get back there and hold the distributor as steady as you possibly can, and ask them to see if the timing reading steadies out. If so, get a new clamp...
And to eliminate any sort of electronic malfunction, disconnect the EST and watch what the timing does. That eliminates a malfunctioning electronic advance as the culprit.
Old Nov 16, 2003 | 11:10 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Distributor endplay, perhaps?
Old Nov 17, 2003 | 03:19 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Nasty stretch in the timing chain? Pickup in the distributor shot?
Old Nov 17, 2003 | 03:21 AM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Also, be careful if you decide to hold your distributor down by hand, I shocked the hell out of my hand turning it once, my cap had a bit of a crack in it and I didn't know and I got one hell of a jump.
dyeager535
Aug 28, 2015 08:10 AM
Bob88GTA
Aug 18, 2015 03:31 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Amillionoh7
Aug 7, 2015 01:24 PM
