Junkyard rear?
Old Nov 18, 2003 | 10:42 PM
camaro_V6_Tuner's Avatar
Car: 2002 Trans Am WS6
Axle/Gears: 4.10
Junkyard rear?
While i see a popular thread on posi rears, i just thought id bering this up. I was at a junk yard the other day and saw a thirdgen z28 with a Drum/Drum rear in it. Could it be a posi? and if so, what gears would be in it? If its a good rear, should i buy it for $25?
Old Nov 19, 2003 | 05:26 AM
ede's Avatar
ede
yes it could be posi and any gear set could be in it. you can pull the cover and look and you'd know for sure
Old Nov 20, 2003 | 12:44 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
They shouldn't have any arguments about you pulling the cover, either. TIP: Bring an empty jug of antifreeze with you, and a blade knife. Lay the antifreeze bottle on it's side, flat on the ground. Use the knife to cut a big circle in the top- voila, instant "low profile" drain pain to slide under the diff cover. Make sure you keep the cap on the antifreeze bottle so the fluid doesn't leak out. That way you're not lying in that stank gross fluid. (Makes me wanna yack every time I smell it...)
BlueIroc-Z
Jun 9, 2019 03:22 AM
budofbama31313
Aftermarket Product Review
Sep 16, 2015 12:29 PM
ZONES89RS
South Central
Aug 14, 2015 09:07 PM
matthew911
Aug 12, 2015 09:38 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
