How can I remove tire from rim?
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
I want to paint my rims and I need to know the easiest or best way to take the tire off.I am going to get a new set of tires anyway, but it would be better if I remove them from the rims.Any suggestions?
-Ken
-Ken
Car: Chevy Cobalt & Camaro
Engine: 2.2 DOHC/3.1
Transmission: Not so slushy slush box/Slush Box
Axle/Gears: Stock 3.23
Use a bumper jack if you have one and a crow bar. I also heard of a method using a spring compressor.. Don't know how to do that though. I painted my rims with the tires on it.. just use alot of masking tape and painters plastic.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
local school auto shop should also do it for free.
ask around a few shops.... and its better to ask in person... you'll find someone local to do it for free/cheap.
Car: 91 Camaro RS
Engine: 3.1L V-6
Transmission: Fresh 700R4
i change tires as part of my job regularly with a coats rim clamp and it's wonderful
but living on a farm i also learned do it with a mini sledge hammer and a crow bar in about 10 mins as well
Why remove tires at all?
Paint rim and protect tires best ya can.
They will be removed when ya get the new tires shortly, anyway.
I've seen the sledge hammer trick at a wrecking yard.
I'll bring the wheel to someone else with the right tool, a real tire changer!
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Ya know I just saw an add for some $20 adjustable metal ring that is meant for painting rims. It like hooks into the outer edge. Wasn't eastwood and I can't find it now.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
http://www.autotoolmart.com/cgi-bin/...29103513797.8a
8089 - Magnetic Rim Masker
$ 19.99
Paint wheels while on tire
Set of 4
Metal ring adjusts for wheel sizes up to 22”
$ 19.99
Set of 4
