Engine light comes on when left on park while running
Old Nov 29, 2003 | 05:00 AM
momokings's Avatar
Car: 1991 Birdy
Engine: 3.1 v6
Transmission: auto
Whats up with that? As soon as I switch to D the Engine light turns off. This only happens if i park somewhere with the car running after a couple of minutes.
Old Nov 29, 2003 | 06:06 AM
ede's Avatar
ede
scan it for codes and see what you get
Old Nov 29, 2003 | 12:55 PM
momokings's Avatar
Car: 1991 Birdy
Engine: 3.1 v6
Transmission: auto
We did that already a while ago and I can't remember which code was exactly but I do remember it had something to do with the idle or something. I'm pretty sure the timing is messed up.
Old Nov 29, 2003 | 04:37 PM
Luder[PAK9]'s Avatar
Car: 1991 Camaro RS
Engine: 3.1L V6 MPFI
It's your idle air control valve. the SES light comes on 22 seconds after ideling when the computer can't get the desired RPM within ~100rpms.
Might just need cleaning, or you can get a new one from Autozonefor $45 (special order)
Old Nov 29, 2003 | 08:31 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
To be absolutely sure, he should still pull the code out. Heck, I'm on my original 1986 IAC motor with 261,000 miles on it. (And original TPS and CTS, too!) Maybe the IAC system just needs to be cleaned. See my message here: https://www.thirdgen.org/techbb2/sho...hreadid=175177
Old Nov 29, 2003 | 09:01 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
OR
He could have a lean idle (mine does...) I get a light if I idle for 45 sec or so. I still havn't been able to find the cause.... Fuel press is fine, EGR working, IAC good, O2 good (going in and out like it's supposed to), TPS works good, I'm runnin 16 deg. advance w/ 89 oct. Still get thea code 44....
Old Nov 29, 2003 | 09:28 PM
momokings's Avatar
Car: 1991 Birdy
Engine: 3.1 v6
Transmission: auto
Just checked the codes today and all I got was 33
Old Nov 29, 2003 | 11:28 PM
Car: 1991 Camaro RS
35--Idle speed cannot be set to desired RPM
42. Fault at electronic spark timing circuit OR
Fault at direct ignition system OR
Fault at fuel cutoff relay circuit
Old Nov 30, 2003 | 01:57 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
Re: OR
Still get thea code 44.... [/B][/QUOTE] Me too, whenever im sitting at idle for more then like 30 seconds or when im on the highway going higher then 70 mph.
Old Dec 5, 2003 | 11:54 AM
mmcdjs's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.1 V6
SES light
Yep. I get the exact same thing when I'm sitting at idle for an extended period of time. I am also having problems getting my idle down below 1000. I can sometimes get it to come down by stepping on the accelerator and letting off quickly though.
Old Dec 5, 2003 | 06:11 PM
br()bert's Avatar
Car: 85 firebird
Yep. I get the exact same thing when I'm sitting at idle for an extended period of time. I am also having problems getting my idle down below 1000. I can sometimes get it to come down by stepping on the accelerator and letting off quickly though. I have the idle problem too, maybe its the iac as far as the idle goes. ? im gonna replace my o2 this summer and see if the 44 goes away.
Old Dec 5, 2003 | 10:54 PM
FbodTrek's Avatar
to brobert-
It won't go away, I've already tried that Your best bet is to try and find the reason for it running lean at idle (heck, I can't even find the reason and I got a snap-on scanner!). As far as I know quite a few things can cause it (TPS, bad o2, Lean injectors, intake leaks, bad MAF). If you ever get yours fixed, let me know how it went down...
Old Dec 6, 2003 | 12:26 AM
momokings's Avatar
Car: 1991 Birdy
Engine: 3.1 v6
Transmission: auto
i'm hoping this can be fixed by adjusting timing to stock 10
Old Dec 6, 2003 | 09:26 AM
br()bert's Avatar
Car: 85 firebird
My car doesnt run lean, this is why im replacing the o2 sensor. Also it looks to be the original one.
Fast355
Dec 2, 2016 06:33 PM
Jae992
Aug 27, 2015 09:07 AM
kyleb24
Aug 15, 2015 08:24 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
