Freeze Plug Replacement
Old Dec 10, 2003 | 07:50 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Alright, my freeze plug that is to the passenger side of the timing chain is leaking.
Anyone replaced this w/o pulling the timing chain cover?
I have heard dent puller to pull the plug out, also tap the top with screw driver, rotate the plug, then pull out with plyers. I dont think a dent puller will fit. Any tips here?
Anyone know a part # or size that I need for this?
Old Dec 10, 2003 | 08:40 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
You probably could pull it without pulling the cover...
As far as pulling it out, they can sometimes be a PITA. Remember they are a PRESS FIT.
You might try using a ratchet extension, and tap one side of the 'lip' of the plug. If you can turn it cockeyed, then you can pull it out with pliers.
You might also drill a hole in the center of it, and try using a pilot bearing removal tool to pop it out.
Take a strong, self tapping screw, screw it in the center, and pull it out.
Those are just a couple of ideas I came up with...
Old Dec 10, 2003 | 08:41 AM
Doward's Avatar
Also, not sure about size (just measure it) but use a brass one, if you can, when you replace it. Much better plug.
Old Dec 10, 2003 | 09:10 AM
Dale's Avatar
Engine: 350 S-TPI
Didnt know brass ones were better, will look for them.
Also screw driver might pierce the steel, something blunt would be less likely,thanks for that idea.
piolit bearing tool, dont have one of them, that I know of.
Doward, can you do me a favor. Since you have an engine out, and no accessorys on the front of the engine, can you measure it for me?
Old Dec 10, 2003 | 11:35 AM
Doward's Avatar
Yeah, I'll brb. *laughes*
Old Dec 10, 2003 | 11:43 AM
Doward's Avatar
Just a HAIR under 1.5"... so I'm going to say a 1 7/16, or a 1 3/8s
Just pick up all the sizes they have up to 1.5"
Old Dec 10, 2003 | 11:46 AM
Dale's Avatar
Engine: 350 S-TPI
Thanks, I'll try to get them from sizes 1.25-1.50 Thanks!!
Old Dec 10, 2003 | 12:02 PM
Doward's Avatar
Not a prob. Always happy to help a fellow thirdgen'r
Old Dec 10, 2003 | 12:57 PM
Dale's Avatar
Engine: 350 S-TPI
Found a whole brass engine freeze plug set on evil bay for 8.93 plus shipping :rockon:
Also emailed and ask if he had a second set laying around for future plans
Old Dec 10, 2003 | 01:52 PM
Briansz28's Avatar
Freeze plugs
My company manufactures plugs for one of the major small parts companies, for rebuilders and the DIY'ers. Advance, Autozone, etc. all have interchange books to get the right set. Best way to remove is with a dent puller. If you knock one end in, make sure you don't lose it inside. Some people coat outside with RTV sealant before install and some don't- don't know which is best. If anyone else is doing the job themselves, Dorman/Motormite has a style of plug called a pilot seal (tm) and it is easier to install with out it cocking sideways.
specialized
Jun 18, 2022 09:26 AM
91REDZ28VERT
Aug 18, 2015 10:16 PM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
