2.8 to 3.1 v6 swap
Old Jan 18, 2004 | 10:29 AM
chevytruck68's Avatar
Car: 86 camaro
Engine: 2.8
Transmission: 5 speed
2.8 to 3.1 v6 swap
Ok i have an 86 camaro with the 2.8 that started knocking. And i want to swap in the 3.1 v6 chevy motor i have from a 91 isuzu Rodeo. The problem is the car has a manual and the 3.1 had an auto behind it. I have been told the that they are balanced differently. Is this true? the 3.1 is supposed to be the same as the 91 to 92 camaro engine. I plan on using just the long block assembly from the Rodeo and want to make sure that the the intake and everything else will bolt up.
And if i need a 3.1 liter specific flywheel does anyone have one i could buy for a reasonable price?
Old Jan 18, 2004 | 11:35 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
your sources are correct.
the 86 2.8 engine is externally balanced.
the 3.1 is internally/self balanced.
not sure if anyone here has some extras. Could get new from parts stores, or try car-part.com, and search for 91-92 3.1 camaro one.
Zane Story
Oct 8, 2015 12:40 PM
usafirebird
Sep 29, 2015 11:58 PM
89bird2.8
Sep 18, 2015 07:46 PM
