Quick question on fuel lines
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
The rubber lines in the engine bay, the one furthest from the engine is the feed line right? w/the return line closest to the engine right?
edit: I really don't want to find out the "smelly" way in my enclosed garagge right now
edit 2: The pic in question, notice the different size of lines used to attach to the fuel rail
Car: 1989 Iroc-Z
Engine: 5.7L TPI
The fuel pressure line is the larger metal line and the fuel pressure return line is the smaller metal line. If you are going to disconnect either one, I would suggest removing the gas cap first so that there is no pressure in the tank.
The Trickster!!!!!!!!!!!!!!
theshackle
Mar 5, 2017 06:37 PM
AkDrifted
Aug 17, 2015 07:45 PM
