Update on my 3.4
Old Feb 6, 2004 | 02:49 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Update on my 3.4
Since I have been hammering you folks for questions the past few months on engine parts, I'll let you know how its going.
a. Picked up engine last week
b. Ripped it apart sunday, monday.
c. Took heads apart, and de-bured them. Not really a port or polish, but got rid of casting flaws, alot at that.
d. Dropped them off for 3angle valve, check deck, crane springs and retainers, 24 new seals all together. This is by the most recommened shop in my area.
e. Left intake with shop above, he is going to media blast it.
f. Installed brass freeze plugs
g. Engine painted to match car.
h. Oil mount mounted
i. New timing chain on, but forgot to install guide, with loose bolts behind cover
j. brand new what appears to be cast billet water pump
k. ordered new dipstick, it has arrived
l. ordered hopeful custom 1.6 rocker setup
m. oil pan has arrived
This weekend, plan on installing oil pan, fixing timing guide, installing idler arm on suspension. Also purchasing head bolts, head gaskets, lt4 knock sensor, and possibly plugs.
:lala:
Old Feb 6, 2004 | 06:31 PM
KED85's Avatar
Excellent & IMPRESSIVE!
Old Feb 6, 2004 | 06:41 PM
eric17422001's Avatar
Car: 3
Engine: inboard
Transmission: underfloor
Dale,
What in the teal blazes is a "hopeful custom" 1.6 rcoker set?
Eric
Great progress BTW- I hope to get my boxed LCA's with the new ES poly bushings, freebie un-bent like the old one track bar, Eibach sportlines and KYB's on the rear, and if I'm REAL ambitious and I don't hit too many snagglies get the frontend re-bushinged (lower control arms) new TRW balljoints, Eibachs, and AGX struts in. Maybe.
Old Feb 6, 2004 | 07:01 PM
bes217's Avatar
This may sound stupid, but why an LT4 knock sensor?
Old Feb 6, 2004 | 10:35 PM
Dale's Avatar
Engine: 350 S-TPI
eric, I will let people know if my idea works.
Bes, the LT4 has one of the noisest valving of any gm engine. Their for, from the factory, between the knock sensor itself, and the knock sensor module (we dont have one, they have removable chip) it helps eleminate spark knock. Install the sensor in another engine, less chance of you getting a wrong reading. If this isnt enough, their is a resistor trick you can do to it also. This orginated in LT1 cars.
Old Feb 7, 2004 | 01:01 PM
bes217's Avatar
Well, I guess you learn something new everyday. Thanks for letting me know.
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
2012sergen11
Oct 13, 2015 07:38 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
92projectcamaro
Sep 29, 2015 07:07 PM
aharvel50
Sep 21, 2015 07:31 PM
