Fun and Cheap Mods
Old Feb 9, 2004 | 10:40 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Fun and Cheap Mods
Now that I have my new motor in place, I figured I'd figure on a few fun modifications. Sonar got me spoiled on exhaust cut-outs (strikes fear in all, lol). I figured Id buy a single unit that can be opened from inside the car. I like the sound of the open 3.4 exhuast, very strong tone (especially for a 6 cyl.). For 40 bucks and some change I can install one right in front of the cat. Another mod I figure would be worth the effort, the Adjustable regulator. If anyone knows where to get a cheap one, let me know. I'd like to know of a few interior mods that can be done fairly easily too. I have the idiot lights in my car, I'd like to remedy that (at least the tach). Anyone who's done it, let me know. Oh yeah, the cooling fan thing....I just wire a grounded switch right? Anyone have other suggestions, let me know.
Old Feb 10, 2004 | 11:53 AM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
As far as interior goes... I believe 4th gen seats are a direct bolt in, so if you can find a 4th gen in a junkyard, try to score em for cheap.
Old Feb 10, 2004 | 01:31 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Cap, What's that?
Old Feb 10, 2004 | 01:39 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Gauge cluster swap is pretty much a no-brainer.. just try to find a cluster from your year vehicle.. petty changes from year to year are annoying to keep track of. You'll also need a new oil pressure sending unit (gauge type instead of switch) and a new coolant temp sending unit (not coolant temp sensor.. two different parts)
Wiring a ground switch for the stock fan relay is definitely the easiest way to go about the fan switch.. Dark green/white stripe
Old Feb 11, 2004 | 01:41 AM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
those manual fan switches get old very fast IF its the only means to turn the fan(s) on.
When i first got my car the fan didnt turn on at all because of the wires and relay being trashed in general.
I bought a hayden adjustable fan switch and a relay. With that and a 180 thermo the car runs at 180 all the time. :hail: PLUS when i do the 3.4 swap i wont have to mess with the stock fan sensor thingy in the passengers side head like others have..:lala:
Old Feb 13, 2004 | 09:53 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
I just made mine so it comes on at all times now,
i was having problems of over heating.
so I'll just swap the $30 motor when it needs swithed
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
92projectcamaro
Sep 29, 2015 07:07 PM
Damon
Sep 26, 2015 04:29 PM
