Sup up the sixbanger
Old Mar 2, 2004 | 12:14 AM
  #51
Z28guy83's Avatar
Car: 83 Z28
Engine: 400sb
well
i hope your not reffering to your 6cyl as a ls1
Old Mar 2, 2004 | 12:17 AM
  #52
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
Re: well
Its got ls1 stickers on the plenum
Old Mar 2, 2004 | 12:35 AM
  #53
F585's Avatar
Re: well
Gee wiz batman! I didn't know 98 SS's came with 2.8s! No, I'm talking about that 320HP (actually 350HP underrated) all aluminum V8 block Home-BOOOIIIIIEEE.:werd: Oh, and it's spelled "referring" but hey you tried your best that's all that matters.
Old Mar 2, 2004 | 12:37 AM
  #54
br()bert's Avatar
Car: 85 firebird
lmao this thread is going to hell. lol
Old Mar 2, 2004 | 12:42 AM
  #55
Z28guy83's Avatar
Car: 83 Z28
Engine: 400sb
ok just checking
well thanx for the spelling lesson mr rogers
Old Mar 2, 2004 | 12:47 AM
  #56
F585's Avatar
Z28guy83 youz gotz hoowk on fonix? wheres agood2.8 when you need him? Anyway, AM91Camaro_RS what mods do you have?
Old Mar 2, 2004 | 12:49 AM
  #57
br()bert's Avatar
Car: 85 firebird
hopefully agood is at his anger man. sessions! Or maybe he's busy writing a huge list on why his 2.8 is better than anyone elses on the earth
Old Mar 2, 2004 | 12:50 AM
  #58
Z28guy83's Avatar
Car: 83 Z28
Engine: 400sb
Originally posted by jon_volk
2 more cylinders :hail:
how about 4 or 8 more cyl if money is no object you could always buy a viper motor or a mercedes v12
Old Mar 2, 2004 | 12:59 AM
  #59
br()bert's Avatar
Car: 85 firebird
Go to bed, you making no sense now man!
Old Mar 2, 2004 | 02:18 AM
  #60
Akshay's Avatar
(not in any particular order)
Tune-up
180* stat w/ lower fan-switch.
K&N airfilter.
Add a posi.
Advance timing 2*.
Mild cam., longer rocker ams
Boring block .30 over, adding bigger valves.
Ignition coil.
Freeflow cat., Freeflowing 2.25"- 2.5" exhaust/muffler
Increasing 2.8 head's compresssion
OR
Adding nitrous or supercharger. (w/ timing retard module) to stock heads.
Subframe connectors, ligher wider wheels
Headers
Akshay
Old Mar 2, 2004 | 02:30 AM
  #61
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
Originally posted by Akshay
...180* stat w/ lower fan-switch...
Is the fan on a temperature switch or is it controlled by the ECM? I'm always confused on this point.
Old Mar 2, 2004 | 04:47 AM
  #62
Jerriko 3.4's Avatar
Car: 1987 Firebird Formula
Engine: 3.4L 207 V6
Transmission: T5 W/C
Man, what a waste of time. So much for having an appreciation for your fellow car buff. I really don't care if its foreign or domestic, 4, 6 8 cylinders, whatever. I look into the work behind the car. You people sound like a bunch of babies. Any v8 can beat a v6 and vice versa. Take my v6, it traps at 95-100 mph and I don't even have the headers, 3.73 gears, aluminum driveshaft or T-5 installed yet. But wasting my time arguing with people on this board while you should be proving it on the streets, that doesn't seem right. I'm not sure but didn't this thread start with someone else asking how they could make their V6 run faster. I have seen this on other sites where someone just starting out asks 'how do I make my V6 faster?' and there is always some flamer or troll saying, 'put a V8 in it'. That's just stupid. Save the boards for people asking questions. If you think you need to prove yourself, don't waste people's time in the threads and give me a call when your in the Chicago area. We'll see what happens.
Old Mar 2, 2004 | 09:08 AM
  #63
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Originally posted by mw66nova
i didn't think that you would remember....i guess i am more well known on this board than i thought. and i do have a v6 in my red car right now, but the 310 is waiting in the wrecked white car for the engine swap party in commerce, GA at the NSCA on May 1st. when two bad cars make one awesome car. anyhow, i am not saying that the v6's can't keep up, but only a few of you guys are actually boosted. most of you are just talk. my "cammed 305" runs consistant 13's on 87 octane. it's hard to get there without boost/nitrous in a v6. possible, but not probable.
No, I just remember people that post on the V6 forum, and I know you used to be one of them.
Your "cammed 305 runs consistant 13's on 87 octane"? Yeah well a look at your webpage shows you've got a lot more than a cam to run those 13.9's!
Wow this turned into a little btch-fest, huh? No wonder i don't spend much time around here anymore. Good way to show off for a new forum member, everyone!
Camy I already put a message up in that other question of yours at the Fabrication forum...
Old Mar 2, 2004 | 09:11 AM
  #64
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Actually AGood2.8 did have a lot of modifications to his car; and gave a ton of technical information over on the Suspension Forum regarding his setup. Did any of you see some of those messages, complete with part numbers and photos and explanations?
Old Mar 2, 2004 | 09:14 AM
  #65
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Wow I'm so glad to see some tech! The fan is controlled by the ECM, but the temp switch in the rear of the passenger head (single green wire goes to it) is the "safety"... it's a redundant system. So you could replace the switch without worrying about the ECM.
Kind of like how the ECM controls the fuel pump relay for startup- but as soon as the car starts, the oil pressure switch bypasses the fuel pump relay- and the fuel pump runs off ot the oil pressure switch. (It's in the GM/Helms wiring diagrams, so nobody try to argue this, as it's been done a million times on thirdgen.org.) You could actually start your car, and either (A) unplug the fuel pump relay, or (B) unplug the oil pressure switch, and the engine will keep going. Now, unplug both, and you won't go anywhere.
Old Mar 2, 2004 | 10:47 AM
  #66
br()bert's Avatar
Car: 85 firebird
I know, seemed like their wasnt a question the guy couldnt answer, He reallty knew his stuff. Too bad he was bipolar, i mean the dude would fly off at the slightest thing !!!
180 fan switch---- i have one, its a hayden adjustable one though
Adjustable to any temp you want to adjust it to(within reason)
I have mine set to around 180 ish and have a 180 thermo installed.
Old Mar 2, 2004 | 02:17 PM
  #67
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
go to page 3 of my cardomain ...my motor specs are there.
Old Mar 2, 2004 | 06:03 PM
  #68
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
yeah, your right TomP i do have a "little more done to it then a cam" but it's fast non-the-less.
Old Mar 2, 2004 | 06:19 PM
  #69
I'm glad to hear this because everyone always says if you get a lower temp thermo you need to mod the chip (to change the fan-on temp). I didn't realize there was a backup switch (although I did know there was the temp sensor on the head). As long as a lower temp one is easy to get my hands on, this will definitely be some good information (my car hates being warm). Does that sensor on the head feed the ECM temp info and turn the fan on?
Old Mar 2, 2004 | 06:25 PM
  #70
...I have mine set to around 180 ish and have a 180 thermo installed.
Wouldn't this cause a bit of a problem? I mean the thermo finally opens and the fan kicks in, the coolant cools off and the thermo closes and the fan turns off, the thermo opens... I'm not saying it will cause a problem, I'm maybe thinking a little too on the ideal side, I'm just curious if that's actually a good idea.
Old Mar 2, 2004 | 06:44 PM
  #71
br()bert's Avatar
Car: 85 firebird
Got me, lol works fine though no problems. I can turn it up or down if i wanted to.
Old Mar 2, 2004 | 06:45 PM
  #72
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
i see where this has gone
Old Mar 2, 2004 | 09:55 PM
  #73
Car: 91 Camaro
i've got a 180* thermo and have a manual fan switch which is almost always on. my car runs 160* and seems to like it.
Old Mar 2, 2004 | 10:06 PM
  #74
I wasn't really thinking that it was bad because it would be running cool, I was just thinking that the constant fan switching and thermo opening-closing might start to wear things out.
Old Mar 2, 2004 | 11:11 PM
  #75
AutoX86Z28's Avatar
Car: 86 Camaro
Engine: none
Transmission: none
Axle/Gears: GT4, 3:73s
BTW someone needs to tell the v8 trolls that chrome valve covers , alt and ait cleaner'd dont make them go faster.
chrome dont get you home:lala:
Old Mar 2, 2004 | 11:16 PM
  #76
br()bert's Avatar
Car: 85 firebird
might wear the thermo out, thats about it. Not like the thermo is expensive anyway or hard to change.
Old Mar 2, 2004 | 11:25 PM
  #77
Generally stops and starts are not good for an electric motor (like the one in the fan), not that stopping and starting in general will wear the motor out but if it turns off and on every five minutes, it's not going to make the motor last longer. Of course the fan motor doesn't really have an initial load, so it can't be too bad (in fact when you are driving, the wind is probably turning the fan some).
Old Mar 2, 2004 | 11:42 PM
  #78
br()bert's Avatar
Car: 85 firebird
when i drive the fan motor turns off due to the air ramming through the rad. Not all the time just if im going like above a certain speed. also outside air temp has alot to do with it also and the fact that my ac condensor is gone, lets the rad breath better.
