seems strange to me
Old Feb 29, 2004 | 10:55 PM
RedTtop5spd's Avatar
Car: 99 SS
seems strange to me
I'm just wondering if anyone else has had this problem. A person at my girlfriend's college saw me changing the oil in my truck and asked if i could look at her RS for her and tell her what this rattling noise was that she just picked up a couple of days ago. I figure why the hell not, I miss my camaro, and at least I get to poke around looking at a nice v6 thirdgen.
Not expecting to find this mysterious rattle on the driver's side without driving it and hearing it, I start looking underneath by the tire and figure while I'm here, might as well check how much brake pad she has left and do a quick checkover on the car as a whole. Stuck my finger through the rim and found the rattle.
Anyone else had the brake pad come loose before?
Yes, she's getting it fixed very soon.
Old Mar 5, 2004 | 12:40 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
There's nothing to really clamp that pad on there; it's normal. There's only two cinch tabs on the outer pad that should be compressed against the caliper; but other than that, the pad just stays in it's spot in the caliper. It won't fall out, but yeah, it's an annoying rattle.
Procedure is; you get the pads all changed, calipers back on. Have a buddy step on the brake pedal (a few times) until pressure builds up (make sure the m/c cap is back on), and then stand on the brakes. While the pads are mashed against the rotor, you go to each caliper with a big set of channel locks (tongue and groove pliers). Top end of the pliers goes against a cinch tab, bottom end goes to the caliper. Squeeze the pliers hard to bend the cinch tab down. Repeat for the other 3 tabs (two on each outer pad).
Old Mar 5, 2004 | 02:03 PM
Car: 99 SS
it's been fixed already. i was just wondering how common it was. i had never run across it before.
Fanatic1074
Oct 3, 2022 05:57 AM
RS Reaper
Oct 17, 2018 07:52 PM
RedLeader289
Sep 23, 2015 06:50 AM
BWilcox
Sep 20, 2015 12:19 PM
///DAN///
Brakes
Sep 17, 2015 07:43 PM
