Can someone identify this leak?
Old Mar 4, 2004 | 04:06 PM
JoshDT91's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 2.8L V6
I have noticed that a clear fluid similar to power steering fluid sits ocassionally on top of the P/S braket. I check the P/S fluid and cannot see it losing any fluid so I am wondering what it can be. Around the P/S cap from time to time there is grease and oily film which I clean up and over time comes back but I assume that is normal. I attached a picture with a yellow arrow showing where the fluid sits on the bracket. It sits just below the bottom bolt that holds the A/C bracket on top of the P/S bracket. I am getting a new P/S cap which is cheap and I thought would be worth the money since it's more than likely as old as the car. One thing I wouldn't want the fluid to be is anything associated with the A/C. Freon would leak but go into the air but something like pag oil that is in the A/C system would it look the same as P/S fluid?
Old Mar 4, 2004 | 04:08 PM
JoshDT91's Avatar
Engine: 2.8L V6
Alright the picture was too big so I had to shrink it, but here it is.
Old Mar 4, 2004 | 09:03 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Mine gets A/C oil on the ps pump when I run it with the bad seal I have on the ac pump
Old Mar 4, 2004 | 09:11 PM
camaro350man's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 Lt
Transmission: 5 Spd
Do you have cruis control in your car? Thanks
Old Mar 4, 2004 | 09:29 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Compressor oil is the only clear fluid I can think of getting there.. there's not many "clear" fluids in an engine to begin with..
Yes, that car is equipped with cruise control. The cable with the 2" long slot on it attached to the throttle lever is the cruise hookup.
Old Mar 4, 2004 | 11:15 PM
JoshDT91's Avatar
Engine: 2.8L V6
Yeah it has cruise control. I can only think of 3 fluids that are clear, compressor oil, brake fluid, and P/S fluid. I checked the back of the compressor where the lines connect on the back and saw no visible signs of leakage. The problem is the A/C bracket is full of grease and oily buildup which makes it hard to find a leak. If it is the A/C compressor where might it leak from besides the back? Around the pulley? The A/C comes out cold and the compressor seems to run fine without binding or slipping.
Old Mar 5, 2004 | 01:50 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
It could also be the cap there was a seal on my PS cap that went bad got a new cap fixed the problem .
Old Mar 5, 2004 | 06:41 AM
Dale's Avatar
Engine: 350 S-TPI
mine leaks from the rear wire sensor, kinda up high.
Old Mar 6, 2004 | 11:51 AM
JoshDT91's Avatar
Engine: 2.8L V6
Well I am getting the P/S cap so we will see about that. I looked at the compressor for leaks and did not find any the first time but I will look again where the wires connect into it.
RS Reaper
Oct 17, 2018 07:52 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
