Speedometer Question?
Old Mar 5, 2004 | 06:01 PM
camaro350man's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 Lt
Transmission: 5 Spd
My speedo jumps around when i first start rolling. Sometimes goes to 40 mph then goes back done and works fine. Anyone know why it is jumping like this. Does this in reverse also? Thanks
Old Mar 7, 2004 | 07:36 PM
WaynesRS's Avatar
Sounds like your speedo cable needs to be lubbed . I think there is an article on it , look up TomP . lube speedo cable and see what you get .
Old Mar 12, 2004 | 12:56 PM
Engine: 2.8 Lt
Transmission: 5 Spd
I believe my car has a digital speedometer. So what would cause this. It jumps around right when i start moving sometimes. Not always though. Once i go above 2 mph it is gone and is fine, sometimes always works. Does the same in reverse. What do you think could cause this?
Old Mar 15, 2004 | 06:07 PM
krazycracka55's Avatar
Car: 92 RS 25th Anniversary
Engine: 3.1
electric u mean?
well to find out u pull the dash cluster out and see if there are cable or no cables behind it
Old Mar 15, 2004 | 10:04 PM
Engine: 2.8 Lt
Transmission: 5 Spd
If it is eletric, what would cause this?
Old Mar 16, 2004 | 07:34 PM
Engine: 3.1
i dunno all my needles started crapping out (ie the skipping like u said) and i got a new cluster on ebay for 85$
Frozer!!!
Jan 19, 2024 04:55 PM
AUZ28
Oct 12, 2015 08:40 AM
AUZ28
Aug 26, 2015 06:08 PM
AUZ28
Interior Parts Wanted
Aug 25, 2015 07:29 AM
redmaroz
Aug 16, 2015 11:40 PM
