fixing rad tank leak?
Car: 87 Firebird (Hasselhoff special)
Engine: 2.8L of PURE STOCK POWER
The passenger side tank of my rad has a little hole through which the coolant pisses out when hot. A new rad costs me minimum of $225. Are there any cheap fixes for the plastic tank? I'd rather do a cheap fix first before replacing the rad.
Is that $225 canadian?? I got a new rad for $125 USD. If I recall, to have it repaired usually costs around $80 USD.....and there are some leaks that CANNOT be repaired.
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Can you order through Summit? If so, squeeze a 31x19 aluminum into there! $160 + s/h!
Car: 1986 Firebird
Engine: 2.8 V6
I tried replacing the side tank and gasket myself once- the side tank cracked in my accident. What a nightmare! Even though I followed the procedure in the GM service manual, I still got leaks. Wound up getting a like-new junkyard radiator for $50... and I'm still using the same radiator- that was back in 1996.
Car: 08 Sierra, 08 Silverado, 91 z28
Engine: 5.3, 4.3, 5.7
Transmission: autos
heres a way that everyone will hate, but ive never had a problem yet in about 5 cars. Barr's stop leak, the kind with the black pellets in it, works great everytime, so does there head gasket repair might i add
theshackle
Mar 5, 2017 06:37 PM
91 rally sport
22
Apr 5, 2016 05:06 PM
