V6 vs V8 fuel pumps?
Old Mar 13, 2004 | 11:00 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
What's the difference between the mpfi v6 and mpfi v8 fuel pumps? Other than $11? They look identical!
Old Mar 14, 2004 | 12:49 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Both are the same working pressure, but the V8 one has a higher flow rate. I intend to swap a V8 unit into my car next time I drop the tank; the pressure regulator should be able to handle the excess flow.
Just make sure you don't order a V8 TBI pump... they only work at 15 psi.
Old Mar 14, 2004 | 02:51 AM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
What exactly do you mean by higher flow rate?
Old Mar 14, 2004 | 02:59 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
They both may be say 150 psi pumps but one flows 20 gallons and hr and the other flows 25 gallons an hr. both still at 150 psi.
just more flow.
Old Mar 14, 2004 | 09:12 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Also look at the corvette one. Agood stated that it had all metal internal gears.
Old Mar 16, 2004 | 09:36 AM
Blue1989RS's Avatar
Car: 1989 RS
Engine: 3.1L + .060" overbore
Axle/Gears: 4.11, Auburn LSD
DONT GET THE TBI PUMP.....I pulled the tank out 3 times trying to trouble shoot that one. And the last 2 times were with 5 gallons of gas in it. Make sure its MPFI!
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
