Supercharger
Car: 86 Z28
Engine: 5.0 TPI
Supercharger
I have a 91 bird with a 3.1 and want to know what kind of superchargers you have b/c im thinking about gettin one this summer.
Thanks for the help/
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
Sorry to say this, but ill do it first, SEARCH FOR EVERYTHING FIRST
with that said i can say the bad news, there are NO real supercharger or turbo kits for our cars. That includes the 2.4 I4, 2.8, 3.1, 3.4 any other motor there is a supercharger kit for. Now if u have a CNC shop and a nac at programing u can have a headunit braket made and a supercharger hooked up.
If u dicide to go custom, u can reuse some of the Inercooler setups from the V-8 side, just add a little diff pipeing. If u do get a custom set up done :hail: YOU:hail:
with that said i can say the bad news, there are NO real supercharger or turbo kits for our cars. That includes the 2.4 I4, 2.8, 3.1, 3.4 any other motor there is a supercharger kit for. Now if u have a CNC shop and a nac at programing u can have a headunit braket made and a supercharger hooked up.If u dicide to go custom, u can reuse some of the Inercooler setups from the V-8 side, just add a little diff pipeing. If u do get a custom set up done :hail: YOU:hail:
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Yep.. no supercharged MPFI 60 degree V6s are out there.. no turbo kits.. if you want boost, you'll have to do it custom.
Engine: LS1, Scrap
I specified MPFI for a reason.. Fageol's blower was for carburated applications. Not sure if they're still in business or not.
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
I emailed Fageol not too long ago (6 months?) and they are still in business as far as I know.
I am conjuring up ideas for a supercharged set up, but it will be a long time before I get anything done if at all, so I won't say anything else.
toronto formula
Nov 10, 2015 06:17 AM
