HP gains from P/S Headers
Old Mar 24, 2004 | 03:07 PM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
Is P/S going to test a car and find gains from the new exhaust set up?
If not does somebody who is planning on getting them have acess to a dyno so they can get this?
If not, and the board wants to come up with the money for me to get headers and before and after dyno tests, I would gladly do it
I am very curious as to what kind of gains these are going to be making.
Anybody who already has headers: what kind of gains did you make?
Old Mar 24, 2004 | 03:33 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
No headers here, but if you checkout firebirdv6.com/camarov6.com, there are lots of peeps w/the 4th gen 3.4 cars w/Pace Setters.
Old Mar 25, 2004 | 11:12 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
Re: HP gains from P/S Headers
count me in too! i'll do a comparison against the old hooker headers! probably won't happen but i'll take a stab at it too!
Old Mar 26, 2004 | 12:19 PM
KED85's Avatar
I say you will gain a solid 10 HP from start to finish of RPM scale. My guessing (as the 2.8's don't "push" much exhaust air as a 3.1 or even a 3.4)
BUT BEST PART IS
The better, quicker throttle response
AND PROBABLY
The limits of the MPFI induction unit will finally be shown!
The RPMS & POWER should be solid for atleast another 500 RPMS due to better pipe breathing.
And also realize that
70% of this site members have aged engines not freshly rebuilt.
Other 30% is a total mix of fresh or swapped long blocks, various sizes. My guessing, not scientific at all.
Thus one HP Gain "answer" will not really be same as another.
Meaning, I seriously expect my 3.4 powerplant to gain most from exhaust system upgrade. An aged 2.8 MPFI will gain the least and it may hurt that aged 2.8 in the end, due to loss of some bottom end torque off line.
When dealing with aged drivetrains, lots of varibles do come into play for end result HP numbers.
And the civil discussion begins.....
Old Mar 26, 2004 | 02:26 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I agree with ked 100%
Every car/combo will be different due to wear, custom setups,
Old Mar 26, 2004 | 06:13 PM
Engine: 5.7 / 7.4
http://www.camarov6.com/ubb/ultimate...177;p=1#000002
just a little FWIW
redformula88
Oct 14, 2015 06:08 PM
Chad Speier
Sep 24, 2015 12:32 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
