How do I adjust the IAC?
Old Mar 25, 2004 | 08:38 PM
camaro_V6_Tuner's Avatar
Car: 2002 Trans Am WS6
Axle/Gears: 4.10
How do I adjust the IAC on my car? Where is it located? Id like to try adjusting this but I dont nkow anythign about it.
Old Mar 25, 2004 | 09:24 PM
Ovrclck350's Avatar
www.thirdgen.org
Click on Technical Articles
Find the one about the IAC and TPS, but ignore the TPS part.
I'd type it all up, but I'm too lazy.
Old Mar 26, 2004 | 01:35 AM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Originally posted by Ovrclck350
www.thirdgen.org
If you have an adjustable TPS then you can't just "ignore" that part. Resetting your minimum air rate will change your TPS voltage at idle.
To be honest, I don't know how to do this without a scantool. There's no way to know what your IAC counts are.
Here's what I do:
1) Clean IAC pintle.
2)Run engine to operating temp. A/C off, adjust throttle screw until IAC counts are around 15-20.
3) Reset TPS voltage to spec. (adjustable TPS only)
4) Disconnect ECM-B fuse for 10 seconds
Done.
Old Mar 26, 2004 | 10:20 PM
Ovrclck350's Avatar
I dont' know about the V6's anymore, the the TPI's are self-adjusting (the TPS). Anyways, that tech article has the proper procedure for adjusting it.
Old Mar 27, 2004 | 11:40 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You mean only the 90-up speed density tpi's were auto-adjusting, right?
For info on the IAC valve, click here: https://www.thirdgen.org/techbb2/sho...hreadid=175177
I've never adjusted the IAC or throttle stop on my car; I've always just kept the IAC system clean- and so far so good, with over 266,000 miles on the clock!
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
thejimsterz28
Sep 30, 2015 08:52 PM
