V6 track passes
Old Mar 27, 2004 | 03:15 AM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
V6 track passes
Went to the track tonite, made 4 runs (woulda made more, had a bad miss...). It was an 1/8 mile, and quite fun. I ran a crappy best of 10.75 with a horrible misfire, 156 BLMs (real lean). I was told that it calculated to a 16.44 1/4 mile... That's pretty crappy. Lucky for me, I have a AFPR coming early next week, Hedders, and cut-outs. I Have an Accel coil ready to go on as well (original one is dying). Just thought I'd let people know what times to expect if your ride is out of tune (or REALLY out of tune...). I'll be looking at 15's by May (14's with a little spray)
Old Mar 27, 2004 | 04:55 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
AFPR prolly won't cure BLMs off that far. You really should stuff the 3.4 injectors in there, especially considering you're looking at opening it up even more.
Old Mar 27, 2004 | 02:04 PM
FbodTrek's Avatar
I do
I do have the 3.4 injectors in there .
Old Mar 27, 2004 | 02:05 PM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
how do you know that you have 156 BLM's and what are BLM's?
Old Mar 27, 2004 | 02:47 PM
Sonar_un's Avatar
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
Its called Block Learn Multiplyer.
Basically it is a measure of how much fuel the ecm has to add to the engine to get it to run properly. 128 blm's are optimal. The ecm isn't having to compensate any more for the fuel. FBodTrek's 156 means that the ecm is trying to add a bunch more fuel to get it to run, so in essence, he is running lean.
Old Mar 27, 2004 | 03:29 PM
FbodTrek's Avatar
A neat little 9000 dollar tool told me
I just hooked up the Snap on scanner and it told me so....lol. A?F ratio was WAYYY off too. I'm surprised the motor runs at all.
Old Mar 27, 2004 | 05:53 PM
TechSmurf's Avatar
Engine: LS1, Scrap
156 *with* 3.4 injectors?!?!?! You've got a *problem*, man. Time to test the injectors.
Old Mar 27, 2004 | 06:49 PM
FbodTrek's Avatar
Where
Where would you suggest I look? I know my fuel pressure isn't right. The injectors are good, They were cleaned and the plugs show even wear (although show signs of an incomplete burn, coil not hot enough?). Any suggestions would be appreciated.
Old Mar 27, 2004 | 07:00 PM
Camaro_Proud's Avatar
Car: 1991 Camaro RS
Engine: 3.1 Crossfire
Transmission: 5 speed
Whats the difference in a regular camaro and a Berlinetta
Old Mar 28, 2004 | 12:01 AM
FbodTrek's Avatar
Tail lights and Gauges....
I think thats it......
(I have a secret though, It's not REALLY a Berlinetta )
jaridjohn
Oct 5, 2015 07:01 AM
racereese
Oct 3, 2015 03:46 PM
