is dynomax still the best?
Subscribe
Mar 28, 2004 | 11:50 PM
i have been here a while...i know...heard it a thosand times....v6, get dynomax. is that still the general consensus??? i mean, you guys have had your dynomax systems for a while now....do you still like them? they still holding up?
anybody bolt them together or is it better to get them welded?
thanks
Reply 0
Mar 29, 2004 | 10:19 AM
Mine's still holding up; bolted it together back in '98.
The previous one lasted from '95 to '98, it "broke" because my right rear hanger had let loose, and the i-pipe was bouncing off the panhard rod. The pipe cracked right at the inlet to the muffler. Since I didn't have my welder back then, I just bought a new cat-back. And if this one cracks again, I can weld it- but even if I couldn't, I'd buy another Dynomax.
There's really no reason to weld it; once you clamp it down, it'll hold. Tip; smear some anti-sieze compound on the outside of the tailpipes, before you slide the pipes into the muffler. This will help you align the pipes to the bumper. You can actually tighten the tailpipe clamps up a bit, but still swivel the tailpipes up/down. Once you get them looking the way you want them, then do a final tighten of the clamps. I've found you get your best alignment when you adjust the tailpipes AFTER lowering the car to the ground.
Another tip; if you want to put exhaust tips on, you'll need to cut the angled slash cut off the tailpipes. This is easiest done (of course) when the tailpipes aren't put on yet. And you can get your best alignment for tips if you set up the tailpipes so the longest horizontal part of the tailpipes is PARALLEL with the ground.
My first cat-back, I didn't cut the slash off, or put tips on, until a year after having the catback. I had aligned the tailpipes so the slash cut was actually "up" a bit more. This put the horizontal (long part) of the tailpipes at a slight upward tilt. So, when I finally did put on tips, my tips were angled upward, and actually rubbed the bottom of the bumper. By then the pipes had taken such a set to the muffler that I couldn't swivel them down.
I hope all that made sense! That whole tailpipe alignment thing would be pretty much the same for any cat-back you buy...
Reply 0
Mar 29, 2004 | 10:40 AM
I finally got my leak fixed, and I still enjoy its tone, and is working.
Mine, they put the clamp bracket on backwards, and I didnt notice it tell it was all bolted up, I wasnt about to take it back down.
Reply 0
Mar 29, 2004 | 02:38 PM
dynomax. is a cat included incat-back? newb question i know, but what can i do?
also i plan on buying pacesetters new headers. so what size should i go with.?
thanks for the help. oh and i am not trying to comandeer the thread, its on topic. so what the hell....
Reply 0
Mar 29, 2004 | 03:45 PM
cat is not included...only things behind it (in flow path) are...intermediate pipe...muffler..tails. i dont know anyhting about the headers
Reply 0
Mar 29, 2004 | 04:26 PM
oh, what is th best cat then? thats what i need, my cat back is fine,....... for now.
Reply 0
Mar 29, 2004 | 06:35 PM
im runnin a slp stainless system in mine. not to ***** on the go and at idle sounds like a mean v8. im happy
Reply 0
Subscribe
