need some advice
Old Apr 25, 2004 | 04:50 PM
Darkness's Avatar
need some advice
i have a 91 firebird 3.1L V6
when im traveling down the freeway i noticed my car shakes at 70-75 mph but if i go to 80mph it stops or if idrive 0-65 it doesnt shake only at 70-75 mph .. now i replaced the shocks the struts
the rotors the bearings in the rotors the tierods the balljoints and the tires i also got my wheels balanced and an alignment
so what could it be??? i thought maybe the bushings??
also if im at a complete stop and im gonna drive off when i step on the pedal and give my car a lot of gas the car jumps like the gear is slipping or something..
Old Apr 25, 2004 | 06:14 PM
84 Z28 5.0 HO's Avatar
Car: 84 Camaro Z28
Engine: 305 L69
sounds like the trans mount is bad
Old Apr 25, 2004 | 07:39 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Yeah I agree on that part....if the car THUNKS from a standing stop thats definitely a trans mount. I had a blown MAJOR trans mount when I first got my car...when I hit the gas, the entire transmission torqued sideways. Dented my floorpans all up.
I imagine that a trans mount MIGHT cause some vibration, but then I dont know. How are your U-joints on the driveshaft?
And one important question...do you feel it through the steering wheel, or through the car? If it's not through the wheel then most like it's not a front-end problem.
Old Apr 25, 2004 | 08:35 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
My guess has to be with the U-Joints. Climb under the car and see if you can shake the driveshaft with your hands, if you hear clunking, then it's definitly the joints that are shot.
Old Apr 25, 2004 | 09:46 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
also check to see if there are any balance weights missing from teh driveshaft while you're down there.
Old Apr 30, 2004 | 07:13 PM
IROC57TPI's Avatar
Check the simple stuff first like see if the tires are all balanced. Also a bent wheel may cause that too but they should be able to tell you if ones bent on a balancer.
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
gord327
Sep 29, 2015 10:18 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mrdevontay
Sep 2, 2015 08:04 PM
