stumble
Old May 13, 2004 | 06:17 PM
mmcdjs's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.1 V6
stumble
Hey guys,
I need some help here. I've developed a real stumble on my car. It can happen at any speed and any rpm. If i accelerate or recel than I can usually get it to stop, but it's been getting worse and I have no idea of what can cause this.
thanks
Old May 14, 2004 | 12:03 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
i also get this at times i think it might have something to do with spark getting to the plugs
Old May 14, 2004 | 12:14 PM
92RSSlowmaro's Avatar
When I first bought my car, it would stumble under hard acceleration. Fresh set of AC Delco plugs and it was as good as new.
Old May 14, 2004 | 01:35 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
i put new ac delcos rapidfires in and it was fine i think its just my coil going now and its not under hard acceleration just a few times a week it might happen
Old May 20, 2004 | 01:35 AM
nadster's Avatar
Car: 89 RS
Engine: 2.8 (the cruiser)
Transmission: 700R4 (TransGo Kit, VetteServo)
Make sure the ignition timing hasn't changed due to a loose distributor bolt. I've had mine loose when setting the timing, reved and the dist would creep closer to TDC on every test rev. A big symptom is mainly using more gas, or louder than normal exhaust and lack of power in some cases.
Hm, also check for vacuum leaks. Could have a leak that happens on occasion like with a cracked hose.
Things to check:
1) Coil,
2) Cap, Rotor, Module
3) Loose cables
4) plugs
5) as mentioned; timing.
6) those connections to the coil, and the dist (the little 18 gauge wires with plugs and stuff).
db057
Jan 10, 2020 08:55 PM
RedLeader289
May 28, 2019 01:47 PM
Logan Bryant
Sep 23, 2015 06:51 AM
RedLeader289
Sep 23, 2015 06:50 AM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
