Running with no Air Filter
Old May 22, 2004 | 07:15 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I went to give someone a jump start today and when i popped y hood my air filter had fallen out of the rubber hose so all the air it had been sucking in was not filterd. I think it may have been like that for about a month at least because i remeber hearing a whistle a while back but didnt think any thing of it. Any way i know it has sucked in gobbs of dirt from the fields by my house and on my way to school. I have noticed it has been stalling in trafic and has been takeing a few cranks to start. Im was allready planing on doing a full tune up next week any way. But would that explain my stalling and hard startS?
Old May 22, 2004 | 08:56 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Id run some upper cylinder lube n cleaner through it. Can of junk you let the car suck up through a vac line.
Old May 22, 2004 | 08:58 PM
FAST RS's Avatar
I was planing on getting the gm top end cleaner. By chance do you have the part number on it at all?
Old May 22, 2004 | 09:03 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Have no idea. But napa sells 3-4 brands that do the same thing.
I hate dealing with the dealer for stuff.
Old May 23, 2004 | 12:38 AM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
drain and flush your oil man
my frind had a pulsar nx that he ran with no air filter and it locked after a year. its not so bad in the snow for no filter but in the summer theres loads of dust in the air
Old May 23, 2004 | 03:18 AM
oil pan 4's Avatar
Car: 89 Firebird
That is not good at all.
I would get that upper cylinder lube but first spary some carb cleaner in there that should help some.
Old May 23, 2004 | 03:32 AM
FAST RS's Avatar
Whats upper cylynder lube? Is it like the top end cleaner? Could this explain my stalling when im in stop and go traffic and brakeing allot it only stalls when i do allot of brakeing and surges like a vacume leak almost. Also it seems to have a hard start now
Old May 23, 2004 | 03:55 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
That top end cleaner is better than carb cleaner but it will have some lube in it. but upper cylinder lube is just that., like mixing oil into the gas. You can find some called upper cyl lube or use good old marvelous mystery oil in your gas after you do the top end cleaner.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Zachattack0925
Aug 12, 2015 09:52 PM
