Rockers/valves??
Old May 25, 2004 | 04:00 PM
camaro350man's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 Lt
Transmission: 5 Spd
Rockers/valves??
I have a ticking coming from my motor, its not to bad but you can here it with the hood up. I think it is coming from the passenger side of the motor and i'm almost postive it is from the top end. I believe it is a rocker, but could it be a lifter? It does not get louder when you rev it up. Its a ticking sound. If its a rocker, what can i do and could it hurt my motor? Or is it a lifter, again could it hurt the motor or what should i do? I'm running 10w-30 in it with mmo (marvel mystery oil). Thanks guys
Old May 26, 2004 | 08:30 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
it could be an exhaust leak too. does it seem to change at all w/ the engine cold and then warming up?
Old May 26, 2004 | 02:28 PM
Engine: 2.8 Lt
Transmission: 5 Spd
Nope it stays the same hott or cold.
Old May 26, 2004 | 02:39 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
AC compressor clutch bearings rattling around post-failure?
Old May 26, 2004 | 02:54 PM
Engine: 2.8 Lt
Transmission: 5 Spd
I started it with the belt of and let it run for a bit so i could here it, and its not an exhuast leak, it sound like it coming from the motor. I just fixed my exhuast, new exhuast manifold gaskets, new y pipe gaskets, need a cat tho i think. It sounds like it is coming from the rear of the motor but the top end of it. Any ideas?
