i think im right but dont know
Old May 26, 2004 | 11:19 AM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
can fuel presure be ajusted? i imagine not but if so how? has any1 ever changed the presure regulator. is somthing suppose 2 be set right?
Old May 26, 2004 | 12:18 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
afpr= adjustable fuel pressuer regulator
some people have modified the stock pressure by using shims/washers to mixed results.
Old May 26, 2004 | 12:24 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Usually though, you only need to adjust it when you've done intensive engine mods, like a camshaft or head porting.
It's not something that can fall out of adjustment. The diapraghm in the fuel pressure regulator can tear, though- but it can be replaced. The FPR is under the plenum (spider-looking thing on top of the motor), it's bolted to the fuel rail, looks like a silver disc with one vacuum line going to it.
Oh yeah the vacuum line can crack, too; that would screw up fuel pressure.
Old May 26, 2004 | 04:17 PM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
good lookin out yall. ill check 2 see if i have bad fuel presure
Old May 26, 2004 | 04:21 PM
oil pan 4's Avatar
Car: 89 Firebird
I have an ajustable FPR and have pictures of it too, heavly modified and on my car domain site.
