Nitrous questions
Old Jun 1, 2004 | 10:12 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Nitrous questions
Ok, I got ahold of a bottle (fianally), I ordered nitrous and fuel solenoids today (80 bux for BOTH!). All I need now is a nozzle and lines from the bottle. Anything I should know before I get ready to spray? I figured I'd back timing off 2 degrees from std. How do I keep things as safe as possible (I won't be spraying over 50hp).
Old Jun 1, 2004 | 11:50 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Throttle microswitch, RPM window switch, protected arm switch, fuel pressure switch, and park/neutral saftey relay.
Old Jun 1, 2004 | 11:51 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
give that new 3.4 a nice big hug before you get in and get ready to hit that button.
Old Jun 2, 2004 | 12:42 AM
FbodTrek's Avatar
Lol, AM91, believe me, I WILL! As for the Fuel pressure saftey switch, even spraying a wet shot?
Old Jun 2, 2004 | 01:13 AM
TechSmurf's Avatar
Engine: LS1, Scrap
Fuel pressure switch is highly reccomended, but not required. The idea has nothing to do with what kind of shot you're running, it's there in case your fuel pump starts to go south while you're spraying. Lean = bad. Lean + Nitrous = new motor.
I reccomend you go read some of the nitrous threads on the power adder board.
MustangBeater20
Oct 29, 2022 09:20 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
