tuning a 2.8L ... HELP!
Old Jun 8, 2004 | 07:43 PM
kridgley's Avatar
Car: 1987 Pontiac Firebird
Engine: 2.8L
hey, I am attempting to Tune a 1987 2.8L V6, I don't really know what all to do to get it running better .... what cams, etc, etc ... any help at all, and anything you can think of to get a little more power (ITS COMPLETELY STOCK--just flowmasters) will be appreciated...thnx
Old Jun 9, 2004 | 06:55 PM
whiteshadow87's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 1991 L-98
Transmission: 700R-4
I have the same engine. Know what i did for more power? Yanked it and put in an L98. Worked like a charm. Thats what i would suggest you do.
Old Jun 9, 2004 | 07:35 PM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
Transmission: Worn-out 200R4
Axle/Gears: BW 9-bolt, 3.27's
I'm sure that wasn't what he wanted to hear, but anyway...
You could try putting steeper gears out back - more off-the-line torque. You could also do some suspension upgrades (if not already done) so the sloppy worn-out stuff doesn't 'rob' the car of power transfer to the ground. Not to mention that once you get that all done, you could take turns faster than most V8 F-bodies could - less weight up front. But if you're looking for a quarter-mile street bruiser, then you might want to look into an engine swap.
Old Jun 10, 2004 | 03:30 PM
kridgley's Avatar
Engine: 2.8L
what should i do with cams ... like what size will appropriatly work with my computer ... and does cold air really do anything .... the suspension sounds good, but i also want to get the most power this tiny engine has to offer.
--(how about borring out ... 30 over?)
Old Jun 10, 2004 | 05:17 PM
pvt num 11's Avatar
Car: 1989 TTA
Engine: LC2
www.60degreev6.com has a lot of stuff to say about the pushrod V6's. He has a list of mods and stuff, as well as where to get cams from, heads, and other cool stuff. That is, if you want to spend the money.
Pac J
May 17, 2020 10:44 AM
Mark_ZZ3
May 24, 2018 01:02 PM
383backinblack
Oct 14, 2015 08:50 PM
bplessy
Sep 30, 2015 12:14 PM
