V6 rpm
Old Jun 12, 2004 | 06:59 PM
7plagues's Avatar
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
V6 rpm
at which rpm would a v6(3.1) run its best and get the best gas milage? is it in the 2500 range or something else?
Old Jun 12, 2004 | 09:31 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
just about 1000, yep, good gas millage, good smooth idle, no problems....1000 rpm's everywhere , round town, highway, race track (go easy on er) and she'll get 70-80 mpg. All truth and honesty, i think mine was doing 2700 or so on the highway, 70-75 mph, ran fine, good, and strong....until these problems invented themselves.
Old Jun 12, 2004 | 11:32 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Doesn't an engine use MORE gas at idle? Isn't that why running the car while waiting for someone for a long time is not recommended if you want to save gas?
Old Jun 12, 2004 | 11:51 PM
7plagues's Avatar
thats what i thought, with the idle thing...i wasnt sure what our cars have for a good rpm to cruise around in.
Old Jun 13, 2004 | 12:01 AM
85f-bird's Avatar
Engine: 2.8L, LS1
i was under the impression that an engine is more effecient at higher RPM's however, i was also thinking that although more effecient, the higher RPM's will cause more fuel consumption, as the engine is moving faster (easier to stay in motion) yet for mainting a propper A/F ratio at the same given RPM more fuel consumption would occur.
Old Jun 13, 2004 | 12:15 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
You just gotta make sure n only use as much pedal as you need. Real light n easy. Its to easy to over use it on a FI car. A tighter return spring can help. I run super tight ones on my carbed V8 car.
It makes you keep it easy. The weight of my foot is plenty to get up to 40-50 in a reasonable amount of time.
Old Jun 13, 2004 | 12:41 AM
92RSSlowmaro's Avatar
having to wind out the motor to keep pace with traffic doesnt help.
Elephantismo
Feb 13, 2019 12:51 AM
ULTM8Z
Oct 2, 2015 01:25 PM
mfp189
Sep 27, 2015 09:25 AM
Damon
Sep 26, 2015 04:29 PM
