Air Pump Hole In Manifolds
Old Jun 19, 2004 | 12:19 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Anyone know what size this hole is? I'm trying to plug this thing off and I can't seem to find the right size plug or even bolt
Can anyone verify if some of these cars came w/o air pumps so that the manifolds wouldnt have this hole? 2.8,3.1, or 3.4's? And if so, anyone got one to sell a friend?
Old Jun 19, 2004 | 06:06 PM
BitchinRS's Avatar
My 92 3.1L doesn't have them, but i have heard of other 92 3.1 that do have them. I haven't found any ryme or reason to determine witch came with ot with out air holes in the manifolds.
Old Jun 19, 2004 | 07:09 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
whay are you blocking it off. You know that it only pulls like 1/4 HP right???
Old Jun 19, 2004 | 07:10 PM
Dale's Avatar
Engine: 350 S-TPI
Thanks, I went and installed another pipe plug in the hole that doesnt have correct threads.
Time to start looking for a better manifold.
Old Jun 20, 2004 | 07:32 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Look for a manifold from a '89 w/o air. Also grab the idler spider from it. The idler setup will prevent the belt from slapping along the long open path (alternator to the crank pully). Can use a stock '89 serpentine belt too.
As for your original question the hole/threads are not a standard size. I actually made a nice brass plug for it but alas it keeps coming loose (just like the stock tube nut always did).
RBob.
mustangman65_79
Apr 14, 2017 05:37 PM
theurge
Aug 21, 2015 12:46 PM
mcquigg
Aug 13, 2015 02:26 PM
Jake_92RS
Aug 11, 2015 10:39 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
