Timing Set
Old Jul 8, 2004 | 05:58 PM
MakeitQuick92RS's Avatar
Car: 1988 Pontiac Trans Am
Engine: 383 Stroker
Axle/Gears: Borg Warner 9-Bolt, with 3.42 Gears
Timing Set
Hey everyone i am swapping my cam this weekend and i wanted to know what timing set you guys recomend? I went to Advanced Discount Auto Parts and they said there are two types and that i have to bring in the old one. Can anyone help.
Old Jul 8, 2004 | 06:56 PM
V6sucker's Avatar
Car: a car being parted out
Engine: blown up
Transmission: in peices
Cloyes double roller. I think P.A.W. sells it for 50 ish?
Old Jul 9, 2004 | 09:10 AM
KED85's Avatar
I install the cheapest priced item I can find, that includes NEW GEARS.
Last Item I installed was $28
MANDATORY
TENSIONER - (MAYBE ONLY GM DEALER ITEM) but is mandatory (except with a double roller chain as it won't fit) ($10)
Balancer snout repair sleeve ($4). Restores tolerences and helps prevent a leak & is cheap insurance, too.
New water pump & thermo stat & double check hoses upon reattachment. Maybe invest in new hoses, too.
($20-pump,$15-stat,hoses $20-ish)
I invest the saved name brand timing chain money on "low maintenance security items"
Enjoy your new cam.
Old Jul 11, 2004 | 06:08 PM
BitchinRS's Avatar
Karl,
Why is the tensioner mandatory? I replaced my timing chain at 275,000 miles. Tensioner was cracked in several spots. I pulled it off and threw it a way. I didn't have time to wait for the dealer to order a new one. I am now at 300,000 miles (gueess it is time to do the chain agin) and have had no problems with out it.
I don't understand the need for the tensioner. It's a timing chain not a timing belt. A chain will break before it can streach far enough to jump a tooth. A jumped tooth is normally caused by worn gears and the tensioner wont be able to stop it from happening.
Old Jul 11, 2004 | 10:15 PM
KED85's Avatar
Flip it around,
Your tensioner was cracked because it was doing it's job of holding chain "in line".
I hear ya on quick availability & such but
on my 3.4 in the Firebird, I feel the need to have a new one in there.
I'm going so far as to remove my newer used timing gear stuff with "few miles on it (like 20,000 miles or so) & replace with new chain, including the new tensioner I obtained.
I neglected to install a new tensioner or a balancer snout sleeve during my 3.4 swap into the Firebird. I included those parts in my Blazer 3.4 swap project.
I have a (Firebird) oil leak at the 3.4 balancer area & I fear for early "wear on the chain" due to usage of used tensioner. Yes new seals were used in the 3.4 swap project
I want my engine to last a very long time.
I BELEIVE IF GM could have eliminated the tensioner (for cost purposes) they certainly would have.
I bow to the "engineer" who insisted tensioner money be spent.
That person must surely know the true mechanical reason.
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Andrew6.688
Dec 13, 2015 10:59 AM
