Lean at WOT?
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
As much as they get in depth... this is the only other board on TGO I frequent...
https://www.thirdgen.org/techbb2/sho...hreadid=214156
I've got to get ahold of a SD 3.1 setup, to figure out the prom info - and build a chip to run the turbo setup!
Also, are you doing 15's on teh stock injectors? If so, get some 3.4 injectors - they are 17pph, instead of your 15pph - and will help you out.
Car: 1991 RS
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Have you tried an AFPR yet? I run one on my setup, I prolly actually run a bit rich up top.... Damn I need a custom chip
Pac J
May 17, 2020 10:44 AM
Damon
Sep 26, 2015 04:29 PM
