Super Coil
Old Aug 9, 2004 | 08:26 AM
knight75's Avatar
Car: 1987 Pontiac T/A with Knight Rider conversion
Engine: 2.8 V6
Transmission: 700r4?
Super Coil
Hey guys I have this Accel Super coil but I'am not sure if it would work with my car. It says its universal but the coils that are on our cars connect differently. has anyone put one of these on their car ?
Thanks guys!
Knight75
Old Aug 9, 2004 | 10:49 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Electronic timing (The EST) requires use of the GM Blaster coil - it looks like the stock one, with more voltage.
You *can* wire it up to work, but you'll end up with more of a points style setup, or an external coil.
Return that, and get the right one for you vehicle.
Old Aug 9, 2004 | 12:00 PM
oil pan 4's Avatar
Car: 89 Firebird
You can use a coil like that if you use an MSD or Accell ignition box like an MSD6.
Old Aug 10, 2004 | 02:01 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You can use that coil (altho I wouldn't); it's easy to convert the 4-pin GM coil connector into a two-wire connection. Terminal "A" of the gray connector should connect to terminal "A" of the black connector. Terminal "B" of the gray terminal should connect to terminal "B" of the black connector.
I forget which is which at the moment, but the pink/black wire of the gray connector would become the coil's positive. white/black is coil negative.
So you'll have two wires going to the positive post of the coil, and two wires going to the negative post.
But... Like Doward said, that's not an HEI coil; aftermarket HEI coils put out over 45,000 volts. That coil probably only juices out 30,000 volts. Like oilpan said, that coil would work well with an ignition box- but on it's own, it won't perform as well.
Old Aug 10, 2004 | 03:55 PM
knight75's Avatar
Engine: 2.8 V6
Hey thanks you guys I'm gonna take your words for it. I'm gonna get that HEI coil instead.
Thanks again Guys!
Knight75
RedLeader289
May 28, 2019 01:47 PM
no green
Jan 9, 2016 09:22 PM
school boy
Oct 22, 2015 11:47 AM
Zell1luk
Sep 29, 2015 10:36 AM
Dragonsys
Sep 25, 2015 03:51 PM
