Is it possible to bypass the A/C and smog pump and just run the waterpump, alt, and power steering? If so what belt is needed? Thanks
-Buck
-Buck
I know on my motor if you just bypass the a/c the belt rubs on the water pump where it meets the tensioner. As far as just bypassing the smog pump I think you need a custom alternator bracket...
Do a search - removing the Air Pump, use about a 91.5" belt. If you remove the A/C, too, no idea then man
