more advice on my cam and stuff to make hp and torque out of my car
Old Aug 17, 2004 | 07:24 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
for one my cam is a crane powermax with 423. lift and 267 duration i havent got it from the mail yet but, while my car lube nice with this performance cam (alot better than stock?)
also what else can i do to make 200+hp in my 3.1 v6 motor?
thank you for any advice,
91greenbird
Old Aug 17, 2004 | 07:39 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
my advice to you is to get a 3.4 ltr
Old Aug 17, 2004 | 08:25 PM
Projek: 85 3800's Avatar
Car: 85 Firebird
Engine: 3800 Series II
200+ hp from the 3.1...............are you loking into forced induction/nitous or just N/A?
Also, what kind of driving do you intend to do w/the car, as streetablility may come into play w/an N/A motor.
Old Aug 17, 2004 | 08:58 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
200 hp is not quite as easy as it sounds. i've done extensive work to my 3.1 and if its making 200+ hp, its not too terribly much over that number.
Old Aug 17, 2004 | 09:53 PM
devianb's Avatar
I think a fair goal is to achieve a ratio of 1 horsepower per cubic inch naturally aspirated. I'm aiming for 170 ponies myself, it will do for my kind of driving. Just my 2 cents. I would like to go with 3.4l swap but I dont know anyone to do swap for me.
Old Aug 18, 2004 | 01:27 AM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Devian....you can do it yourself..... It's actually very easy and straightforward once the two motors are sitting beside eachother (and you have all these great folks to help you!). While it's out swap the cam and port your heads. A good cam and hedders got me into the 15's (along with other stuff of course), and my cam is rather mild.
Old Aug 18, 2004 | 04:05 PM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
Is everything interchangable from the 3.1 to the 3.4? I've been upgrading things 1 at a time on my 3.1 and I would like to goto a 3.4 in the future but would't want any upgrade going to waste so if there are things that I can't swap over I'd like to avoid them.
How difficult is a cam to install for someone who isn't too bright? I'm not looking for 200+ hp or anything, just more power outta my lil 6. Do you always have to do springs and lifters and all that?
Old Aug 18, 2004 | 04:57 PM
biff85ta's Avatar
Car: 04 Vette
Are you still in Carbondale?? I know of a place that would do it but he is about 30 minutes from you.
Old Aug 18, 2004 | 05:27 PM
FbodTrek's Avatar
For the springs it really depends o the cam profile. It's not that complicated really, getting down to it is the tricky part (avoiding breaking vaccumn lines). for a .42 lift and lower profile cam, stock springs will work (but you wont make as much power). The cam I use is slightly over that figure (.423 I , .443 E) so i swapped in some higher lift springs, retainers an locks. Higher valve seat pressure is going to allow forslightly higher rpm as well (which can mean more power too). If you were to pay a shop to swap everything for you I can't see them charging more than about 350 USD. Hope that helped.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
Fronzizzle
Aug 9, 2015 01:15 PM
gwade12
Aug 8, 2015 08:17 AM
