Where can I find out if a parts illegal
Car: 90 Camaro
Engine: v6 3.1L
Transmission: 700r
I live in California and I was summit racing adding parts to my cart to get a feel of how much it would be. Then i put my info in to checkout just to see shipping and hoping I wouldn't get nailed with the 8.25 tax
. At the top of the screen it said some parts are illegal to california emissions, first I thought it was the dynomax cat. So i took it off and still got the same message
heres what I had
Dynomax Catback - Part # 17493
Dynomax Cat- 15735
Hypertech powerstat- HYP-1006
B&M Shiftkit-BMM-70239
MSD Ignition-6200
Spark Plug Wires-Accel 8879
if anyone can help it would be appreciated, sorry I have a lot of questions but this board has helped me a lot
. At the top of the screen it said some parts are illegal to california emissions, first I thought it was the dynomax cat. So i took it off and still got the same messageheres what I had
Dynomax Cat- 15735
MSD Ignition-6200
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Parts
It might be the powerstat but there is nothing there that would cause you a problem here.
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
They say that about everything. I bought carpet for my car from them and the guy on the phone had to give me the speech Saying some of the parts i may have purchased my not be used on a polution controled veachile in california and may not be 50 state legal. I had to laugh at that. I think it is more a legal thing to cover there ***.
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
was that carpet ****....LOL...it would definatly be a pollution part then....LMAO
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
when in doubt, contact the parts manufacturer to see if part is/needs to be **** C.A.R.B. certified.
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
Maybe the carpet was made 100% from lead and it added so much weight that it actually changed the fuel consumption.
Originally posted by kretos
basically theres nothing you can buy that you can get into trouble for
ie. jail time
ie. jail time
Car: 1986 Firebird
Engine: 2.8 V6
If the exhaust system is factory replacement AFTER the catalytic convertor(s), it's usually 50 state legal. The only un-legal part might be the noise generated from the muffler.
To dig up California Air Resource Board's Executive Order (smog exempt) numbers, visit http://www.arb.ca.gov/msprog/aftermk...es/amquery.php . That's how I found out Pacesetter's EO # for our headers.
Also, if a piece is just an aftermarket replacement "consumable", it should pass. That includes air filters, fuel filters, spark plug wires, distributor cap/rotor, etc. It wouldn't include spark coils, ignition boxes, camshafts, or catalytic convertors- THOSE you'll have to make sure are emissions legal. MSD gets EO #s for most of their streetable equipment.
Don't get the B&M Shift kit, buy the TransGo kit- the B&M kit can hurt your transmission. (And I'm a B&M fan!!) But anything with the trans is going to be legal, because it doesn't affect emissions. Same with suspension. If you change the rear gear in your axle, it might raise the emissions of your car and cause you to fail though.
