AC Bracket
Old Oct 4, 2004 | 07:28 PM
cybrmartian's Avatar
AC Bracket
I recently bought a 85 firebird with a 2.8 v6 and come to find out the AC Compressor bracket is actually broken in two pieces. the AC works fine and living in Florida it is a good thing to have around. The only problem is with the bracket broken I can't tighten the belt enough to actually use the AC safely. I have been searching for a replacement around here for about 2 weeks now and even called a couple places out of state and no luck. Does anyone know where I can find this bracket, Of course the dealer said it is a discontinued item.
Matt
Old Oct 4, 2004 | 07:37 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
ANY junkyard should have one. Where in Florida are you?
Old Oct 4, 2004 | 07:56 PM
bracket
I am in dunnellon and work in ocala and I have called almost everywhere and have a couple other places to visit in belleview and a few other around. but won't be able to until next wednesday since that is going to be my next day off. of course most of that places I call say they don't have any cars back to 85 and only have newer ones. I have tried LKQ(damrons) in Crystal river and they said they don't sell brackets and he laughed when I asked what they did with them.
Old Oct 4, 2004 | 08:56 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
car-part.com, search on say, compressor, then call n ask for just the bracket.
Old Oct 4, 2004 | 10:52 PM
oldschool's Avatar
Car: 1985 Pontiac Firebird
Engine: 2.8 LB8 HO
Transmission: 700R4 with OD
Axle/Gears: 10 bolt 7.625 open-factory 3.42
The 1985 2.8 AC bracket in question is composed of a bottom cradel section, and two side pieces all held together with long bolts. All three pieces are discontinued by GM. The good news is that the same bracket was used again in 1986 on the 2.8's with AC, the last year for individual accessory drive belts. Check out Camaro Heaven, House of Camaro, IROCZDAVE, Hawks, etc... This item should not be hard to locate.
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
meeklay812
Oct 1, 2015 03:46 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
armybyrd
Sep 26, 2015 03:37 PM
